I have searched on this question for a while but not found anything. Is there a program out there - freeware or cheap - that will let me convert a dvd movie into vcd or svcd in one step? or almost one step? I am not concerned about menus, multilanguage tracks, trailers, etc. I just want the movie and music and audio track.
Thanks in advance.
Sorry for the late reply, but I only recently found this forum. In any case, if you are on a Windows machine, use EazyVCD. There is an older version which is free, and a newer version which is low cost shareware. It is very easy to use, and produces good results if all you are looking for is basic conversion, as you seem to be. No extra audio tracks, no subtitle support, but it gets the job done otherwise.
How to embed subtitles into mkv STEP BY STEP using MKVMERGE and MKVEXTRACT
By lelouch283 in forum SubtitleReplies: 30Last Post: 23rd Jun 2017, 14:04 -
MP4 X.264 to AVI XviD - Hard Sub with ssa subtitles (1 step or 2 step?)
By ssray23 in forum SubtitleReplies: 4Last Post: 29th Aug 2010, 19:35 -
Need DVD Rip Step-By-Step Instructions For Best Quality
By bht42 in forum DVD RippingReplies: 4Last Post: 26th Jul 2010, 09:28 -
The Complete Step By Step DVD Ripping/Burning Primer for Mac...?
By oliasdoug in forum MacReplies: 0Last Post: 10th Nov 2009, 07:04 -
Audacity guide for beginners, step-by-step
By AleksandrIgnatov in forum User guidesReplies: 3Last Post: 20th May 2007, 20:34
