I'm starting to shop for a new pc to use for video editing / authoring.
Will TV-Out give me a reasonably close idea of editing results ?
If I do color-correction, noise-removal, etc, would the TV display look quite similar to the final burned DVD,
or would I be better off to just continue doing test burns using Re-Writable disks?
I hope y'all have some advice for me.
Thanks in advance.
grannyGeek ~~
Antique Newbie -
TV out on a typical display card is completely arbitrary based on overlay settings*.
Prosumer editors (AVID, FCP, Premiere, Vegas, etc.) have monitor paths over IEEE-1394 or through hardware interface cards. Vegas 6 and later have calibration procedures for LCD preview monitors.
*TV out is derived from a deinterlaced RGB reconstruction of the timeline video. The DVD MPeg2 encoder generates 16-235 referenced 4:2:0 YCbCr. -
Ah, so it sounds like something I can't really count on until I have the beast in hand.
I don't have one of the better-quality editors, and budget wouldn't allow purchase of one(don't you just hate a sulky checkbook?), so I think I would have to rely on tweaking the pc settings themselves.
Does anyone out there have a product line to recommend?
Or maybe I'll just continue to use RW disks, it only takes a few minutes to burn a quick tester.grannyGeek ~~
Antique Newbie -
It's possible to perform a crude levels calibration of the S-Video output using proper test signals and measurement equipment but color match is problematic due to different colorspace, gamma and the effects of S-Video NTSC encoding.
http://www.kiva.org/about -
For my purposes, that sounds like WAY more trouble than it's worth, with a doubtful outcome at the end of it all.
thank you so much for your advice!grannyGeek ~~
Antique Newbie
please recommend tool for editing + adding audio track to video
By lovelove in forum Newbie / General discussionsReplies: 4Last Post: 26th Sep 2011, 00:10 -
Best all round tool to convert video formats, basic editing, etc.
By ian_g in forum Video ConversionReplies: 9Last Post: 16th Mar 2011, 06:21 -
The Best and Simplest Video Editing tool.
By LarryLaser in forum DVD RippingReplies: 1Last Post: 27th Nov 2009, 00:57 -
What tool for video property editing?
By Nator in forum Newbie / General discussionsReplies: 3Last Post: 20th Sep 2007, 03:25 -
Tool for editing Divx
By ghassan99 in forum EditingReplies: 2Last Post: 18th Jun 2007, 19:02
