Ok, I have been looking to upgrade and now have a little money to do so. I plan on being in the neighborhood of 225. I will be upgrading from an athlon xp 2000+ with 768MB of ram. I use Ubuntu 6.10.
Now looking at my options I feel it would be best to upgrade my Motherboard, Ram, and Processor, but would still like to be able to upgrade down the road my video card and perhaps a processor if needed. I am currently looking at two configurations I found at a local store (PC Club)
Config 1:
Gigabyte MATX CONROE 945GZ GA-945GZM-S2
INTEL Pentium D 820 2.8GHz RETAIL processor (Pentium D 915 +40)
KINGSTON 512MB Valueram DDR2 533 - PC4200 CL4
Total $234.98
Config 2:
GIGABYTE GA-M61VME-S2 nForce 400 mATX Motherboard - Socket A
AMD Athlon 64 3500+ Socket AM2 (Retail)
$224.98
I do light gaming (Heavy gaming is what the 360 is for), but what I really want to do is start encoding videos for my PSP as well as have a faster machine.
I haven't really heard much about the Pentium D, heard much more about the core duo, and the X2 is an option to upgrade at a later date (The amd board supports X2 while the intel board supports Core 2 Duo). I figure dual core 64-bit is the way to go. Im just not sure the performance difference I will see between these two so I figured I would ask here.
Hunting, sure i'll go hunting. When is cow season?
Upgrade now to a Pentium D? This is two generations of CPU behind and, frankly, I doubt the 2.8G will give you much edge over the existing configurtation you have.
You should be looking at a Core 2 Duo CPU and a motherboard that is compatible.The more I learn, the more I come to realize how little it is I know. -
Here's a mobo combo w/ram for you:
AMD ATHLON 64 3200+ Orleans 2.0ghz AM2 processor $79.00
http://www.newegg.com/Product/Product.asp?item=N82E16819103031
CORSAIR DDR2 800 (PC6400) RAM (2) 512 mb $111.00
http://www.newegg.com/Product/Product.asp?item=N82E16820145566
BIOSTAR NF61VM2 Socket AM2 NVIDIA GeForce 6100 Micro ATX Mobo $53.99
http://www.newegg.com/Product/Product.asp?item=N82E16813138036
Total w/out shipping cost is $243.99. The BIOSTAR mobo has built in video. You can always decide later to install a PCI-E video card. It's over your budget of $225.00 but with this AM2 processor you'll still be able to upgrade later to a AM2 dual core processor.
Unfortunately with your budget of $225.00 it wouldn't be enough for a 2 core duo processor, mobo and ram combo. Unless you wait until the 2 core duo processors drop in price.
Intel Core 2 Duo T7500 2.20 vs. Intel Core 2 Duo E8400 3.0
By vatkat234 in forum ComputerReplies: 6Last Post: 27th May 2009, 11:42 -
Intel Q6600 Kentsfield or Intel E8400 Wolfdale??? Help me decide which one
By budz in forum ComputerReplies: 33Last Post: 12th Mar 2009, 01:19 -
Encoding - Xp or vista, Athlon or Intel?
By RKDYork in forum Newbie / General discussionsReplies: 6Last Post: 18th Jan 2009, 20:57 -
3.4 Pentium 4 or 935 Pentium D?
By DarrellS in forum ComputerReplies: 6Last Post: 12th Jan 2008, 00:58 -
GIGABYTE motherboard / Intel Pentium D 935
By thebirdf in forum ComputerReplies: 4Last Post: 2nd Nov 2007, 14:50
