  1. Hi CB. I've been using SVCD2DVD for a couple years now and
    love the "Burn with ImgBurn" shell extension utility.
    I have been looking for a way to eliminate any dependence
    on Nero. About all I use it for now is to burn dvds with .avi files
    to play on my stand-alone divx DVD Player.
    Would it be feasible to enhance the shell extension
    so as to take selected .avi files or a folder full of .avi files and
    burn a DVD in ImgBurn with all the right options
    (No conversions just setting all those arcane check boxes
    in ImgBurn so that the stand-alone with recognize the
    divx files.)
    If I could easily do that then I think I wouldn't bother to install
    Nero on my next PC. I kind of have that 500 LB gorilla on my
    system just for that small task at this point
  2. Turns out if I use the same options I was using in Nero 6.x I can burn a folder of .avi files that my Phillips dvp 642 will play. Didn't work the first time I tried it so I guess I just have to be more persistent and try everything at least twice. With Vista and all the rest keeping CB busy I guess there's no need for this feature request anymore.
