    Apr 2005
    Blacksburg, VA USA
    Can someone please tell me what I'm doing wrong? I snagged
    Blockbuster's Superbowl "How To Use A Mouse" ad, dropped the
    FLV onto iSquint, and got an MP4 file (28 seconds for the ad).
    So far so good.
    I opened it in QuickTime Pro (7.1.3 under 10.4.8) and it played
    fine. I went to export it as a WMV, and the result was half of
    the ad (14 seconds). I tried another download (Blockbuster stuff
    excised, 14 seconds). Same process. Same result. The WMV was 7
    seconds long, again exactly half.
    What's going on? How can I correct the problem?
    Help!!!
    Al Bloom
    Apr 2005
    Blacksburg, VA USA
    Never mind. Seems with the free Flip4Mac, QT will only export
    one half of the video, up to a max of 30 seconds.
    The Flip-folk want you to spend $49 to upgrade to Studio.
    I believe I can get the same capability (and more) with
    VisualHub for $23.
    Al Bloom
  3. why would you want to export as a wmv file if you have it in flv format?
    Apr 2005
    Blacksburg, VA USA
    Because I have a friend who doesn't know how to deal
    with any other video format.
    It's easier to give her what she knows than to teach her
    anything new.
    Al Bloom
    May 2004
    Use VLC to recode to WM1 or WM2. It's free.
    Open File> click Streaming Saving, in the new window click Browse at the top to give it a default file name. Amend the name .wmv, Play File Locally, under transcoding options for video and audio check both, choose wm1 or 2 and as high a bit rate as you can afford for each.
    Jan 2007
    Well worth the $49. for Flip4Mac. V-Hub doesn't come close to the quality and features. Here's the F4M general spec: supports WM7, 8, 9, 9 Advanced, ISO MPEG 4 V1.0 & V1.1, Microsoft MPEG 4 V2 & V2 along with multiple audio codecs. Web streaming. Import/export, FCP compatible, etc.
    VisualHub for $23.
