I'm using a Mac G4 with Virtual PC. I need to Rip a DVD file to edit in Adobe Premiere and/or Final Cut Pro to later be burned using iDVD. Is the process different for a MAC? Should I use Virtual PC and rip with Smart Ripper? Once I have the .vob file should I then use DVD2AVI to get a .d2v file? Can I edit the .d2v file in Premiere or do I need to do something else?
Basically all I need to do is
1. rip
2. edit
3. burn
Thanks,
John -
Try DVDExtractor 0.9b. This is freeware that allows you to copy (rip) the DVD to your desktop (so you can watch it without any delay), and you can change the regioncode!
Go to http://www.riphelp.com/downloads/dvdextractor.html for a free download.
Good luck
Couldn't rip Vob files onto my computer. best program for mac.
By Tintin11 in forum DVD RippingReplies: 2Last Post: 3rd Nov 2010, 22:05 -
Dvd rip(HD) in mac - Mov,mpg,avi
By nimrodm in forum MacReplies: 3Last Post: 9th Feb 2010, 07:33 -
Mac format HD DVD, How can I rip?
By haymes in forum Newbie / General discussionsReplies: 16Last Post: 22nd Mar 2009, 16:45 -
Tool to Rip a DVD on MAC for backups?
By fiiido in forum MacReplies: 6Last Post: 22nd May 2008, 07:29 -
New Mac user: Looking to rip, compress and burn DVD's on iMAC
By Jabroni4872 in forum MacReplies: 6Last Post: 12th Apr 2008, 21:53
