I'm new yadda yadda, Anyway I recently put in a new dvd burner my last one broke, and all was working fine until I ran out of dvds. I have bought 3 different brands and none of them work with my burner. I believe this to be a problem with the drive I just don't know what it could be. Any suggests would be a load of help, thanks.
What's the manuf and model # of your burner?
What's the brand on the DVDs that worked and that did not work?
You can also look at nomorecoasters.com to see if you are getting some bad media.XP
Intel Celeron D 335 Prescott 2.8GHz Socket 478 Pro
600GB
2G
ATI Radeon X1600 Pro
GIGABYTE GA-8I848P-G Socket 478 Intel 848P ATX Int
Lite-On DVD SOHD-16P9S
Hauppauge WINTV-PVR-150 PCI Interface Tuner Card -
The burner is a Lite-on DVDrw SOHW-1633S I've tried Magnovox and Sony discs and they didn't work. I double checked on Nomorecoasters and the sony ones are some of the best. The ones that worked prior were playo.
I also have a Lite-on DVDrw and an NEC drive, and I've had very good luck with Verbatim DVD+R media !!!! 8)
" Who needs Google, my wife knows everything"
I have an annoying problem with my dvd burner.
By roomgrey in forum DVD & Blu-ray WritersReplies: 6Last Post: 19th Oct 2010, 14:43 -
USB External Burner Problem- help?
By Super Warrior in forum ComputerReplies: 1Last Post: 3rd Jun 2009, 23:50 -
rca dvr dvd burner problem
By ziggy919 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 1st May 2009, 20:38 -
Benq EW162I DL burner Problem
By wanghiking in forum Authoring (DVD)Replies: 9Last Post: 20th Nov 2008, 20:09 -
Problem with HP DVD300e burner
By shinyranker in forum Authoring (DVD)Replies: 4Last Post: 22nd Jun 2007, 08:18
