What is the advantage of using Frameserve with Virtualdub as opposed to just bringing your AVI file directly into TMPGEnc? My current method is to run the Capture, which creates the AVI. Exit Virtualdub. Open TMPGEnc, load up the AVI file and use Source Range.
Bud
It helps to apply some filters in VirtualDub before encoding. You could add subtitles, carry out Resizing,remove logos,adjust brightness /contrast/color etc . It is advisable to resize in VirtualDub than TMPGEnc as this could improve the encoding speed.
Makes sense to me, was not sure about the WHY. Now have a better understand of the process. Many thanks for the quick response.
Bud -
Its also to get around large files. If you capped in virtualdub and your files end up bigger than 4gig, it will split it into 2 files. You can't load 2 avi files into tmpgenc directly. But you can easily framserve both files into one mpeg.
Export to FLV using virtualdub and frameserve
By itoo73 in forum Video ConversionReplies: 6Last Post: 5th Jan 2013, 23:46 -
How to frameserve from virtualdub to ProCoder2 ?!?!
By simps in forum Video ConversionReplies: 22Last Post: 14th Feb 2010, 13:16 -
Frameserve from virtualdub to HC
By SatStorm in forum Video ConversionReplies: 2Last Post: 12th Jun 2009, 07:24 -
Is it possible to frameserve with Virtualdub to MeGui?
By salidarius in forum Video ConversionReplies: 8Last Post: 13th Feb 2008, 06:41 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 09:38
