hi guys,
Ive been using dvd2svcd v2.1(2.1.2474).
i tried a 3 movie disc the other night with text menu and audio.
followed the online help.
when the disc was burned,here are the results:
dvd player 1 : black screen,audio playing.would still play movies from menu even though i was navigating blind.
dvd player 2 : menu screen but the player was in a play loop (just kept bringing up OSD PLAY),i could navigate but with the player constantly flashing up play,every time i tried to navigate,the player would just "reload" the disc, no audio.
xbox media centre - plays perfect.
Any ideas where im goin wrong? following the online tutorials and just seems to be a compatibility issue??
thanks in advance...
Is this your first try at an audio menu with SVCD2DVD? Which type of audio (AC3, MP3, etc.) did you choose for your menu? Can you post the log file for this disc?
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
I Used the old version more,but yes first go with music/menu - heres the section of log for dvd menu:
---------------------------- ENCODING MENU ----------------------------
TV Standard: PAL
Image size: 768x576
Resize size: 720x576
01:34:58: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
01:34:58: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
01:34:58: libavutil version: 49.0.0
01:34:58: libavcodec version: 51.4.0
01:34:58: libavformat version: 50.2.1
01:34:58: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special)
01:34:58: Input #0, mp3, from 'S:\music\Lemonheads\Evan Dando\Evan Dando - Baby Im Bored\Evan Dando - 02 - My idea.mp3':
01:34:58: Duration: 00:02:33.7, start: 0.000000, bitrate: 128 kb/s
01:34:58: Output #0, mp2, to 'C:\Program Files\BadgerIT\SVCD2DVD v2\menu\menu.mp2':
01:34:58: Stream #0.0: Audio: mp2, 48000 Hz, stereo, 224 kb/s
01:34:58: Stream mapping:
01:34:58: Stream #0.0 -> #0.0
01:35:02: video:0kB audio:4212kB global headers:0kB muxing overhead 0.000000%
01:35:03: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
01:35:03: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
01:35:03: libavutil version: 49.0.0
01:35:03: libavcodec version: 51.4.0
01:35:03: libavformat version: 50.2.1
01:35:03: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special)
01:35:03: Input #0, image2, from 'C:\Program Files\BadgerIT\SVCD2DVD v2\menu\background%d.jpg':
01:35:03: Duration: 00:00:00.0, start: 0.000000, bitrate: N/A
01:35:03: Stream #0.0, 25.00 fps(r): Video: mjpeg, yuvj420p, 720x576
01:35:03: Output #0, rawvideo, to 'C:\Program Files\BadgerIT\SVCD2DVD v2\menu\backgroundES.mpv':
01:35:03: Stream #0.0, 25.00 fps(c): Video: mpeg2video, yuv420p, 720x576, q=2-31, 1000 kb/s
01:35:03: Stream mapping:
01:35:03: Stream #0.0 -> #0.0
01:35:03: video:87kB audio:0kB global headers:0kB muxing overhead 0.000000%
01:35:04: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
01:35:04: INFO: [???] File C:\Program Files\BadgerIT\SVCD2DVD v2\menu\backgroundES.mpv looks like an MPEG Video stream.
01:35:04: INFO: [???] File C:\Program Files\BadgerIT\SVCD2DVD v2\menu\menu.mp2 looks like an MPEG Audio stream.
01:35:04: INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
01:35:04: INFO: [???] Found 1 audio streams and 1 video streams
01:35:04: INFO: [???] Selecting dvdauthor DVD output profile
01:35:04: INFO: [???] Multiplexing video program stream!
01:35:04: INFO: [???] Scanning for header info: Video stream e0 (C:\Program Files\BadgerIT\SVCD2DVD v2\menu\backgroundES.mpv)
01:35:04: INFO: [???] VIDEO STREAM: e0
01:35:04: INFO: [???] Frame width : 720
01:35:04: INFO: [???] Frame height : 576
01:35:04: INFO: [???] Aspect ratio : 1:1 pixels
01:35:04: INFO: [???] Picture rate : 25.000 frames/sec
01:35:04: INFO: [???] Bit rate : variable
01:35:04: INFO: [???] Vbv buffer size : 34816 bytes
01:35:04: INFO: [???] CSPF : 0
01:35:04: INFO: [???] Scanning for header info: Audio stream c0 (C:\Program Files\BadgerIT\SVCD2DVD v2\menu\menu.mp2)
01:35:04: INFO: [???] MPEG AUDIO STREAM: c0
01:35:04: INFO: [???] Audio version : 1.0
01:35:04: INFO: [???] Layer : 2
01:35:04: INFO: [???] CRC checksums : no
01:35:04: INFO: [???] Bit rate : 28672 bytes/sec (224 kbit/sec)
01:35:04: INFO: [???] Frequency : 48000 Hz
01:35:04: INFO: [???] Mode : 0 stereo
01:35:04: INFO: [???] Mode extension : 0
01:35:04: INFO: [???] Copyright bit : 0 no copyright
01:35:04: INFO: [???] Original/Copy : 1 original
01:35:04: INFO: [???] Emphasis : 0 none
01:35:04: INFO: [???] SYSTEMS/PROGRAM stream:
01:35:04: INFO: [???] rough-guess multiplexed stream data rate : 0235296
01:35:04: INFO: [???] target data-rate specified : 10080000
01:35:04: INFO: [???] Setting specified specified data rate: 10080000
01:35:04: INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
01:35:04: INFO: [???] New sequence commences...
01:35:04: INFO: [???] Video e0: buf= 0 frame=000000 sector=00000000
01:35:04: INFO: [???] Audio c0: buf= 0 frame=000000 sector=00000000
01:35:04: INFO: [???] STREAM e0 completed @ frame 11.
01:35:04: INFO: [???] STREAM c0 completed @ frame 6418.
01:35:04: INFO: [???] Multiplex completion at SCR=13871104.
01:35:04: INFO: [???] Video e0: buf= 0 frame=196612 sector=00000024
01:35:04: INFO: [???] Audio c0: buf= 2688 frame=006418 sector=00002136
01:35:04: INFO: [???] VIDEO_STATISTICS: e0
01:35:04: INFO: [???] Video Stream length: 88855 bytes
01:35:04: INFO: [???] Sequence headers: 2
01:35:04: INFO: [???] Sequence ends : 0
01:35:04: INFO: [???] No. Pictures : 12
01:35:04: INFO: [???] No. Groups : 2
01:35:04: INFO: [???] No. I Frames : 2 avg. size 11665 bytes
01:35:04: INFO: [???] No. P Frames : 11 avg. size 2229 bytes
01:35:04: INFO: [???] No. B Frames : 0 avg. size 0 bytes
01:35:04: INFO: [???] Average bit-rate : 1366800 bits/sec
01:35:04: INFO: [???] Peak bit-rate : 797600 bits/sec
01:35:04: INFO: [???] BUFFERING stream too short for useful statistics
01:35:04: INFO: [???] AUDIO_STATISTICS: c0
01:35:04: INFO: [???] Audio stream length 4313568 bytes.
01:35:04: INFO: [???] Syncwords : 6419
01:35:04: INFO: [???] Frames : 6419 padded
01:35:04: INFO: [???] Frames : 0 unpadded
01:35:04: INFO: [???] BUFFERING min 15 Buf max 683
01:35:04: INFO: [???] MUX STATUS: no under-runs detected.
create sub file....done.
running menu muxer....01:35:06: MUXRATE =4400
01:35:06: after read_bmp(): xd=720 yd=576 x0=0 y0=0
01:35:06: Found EOF in .sub file.
01:35:06: warning, sub on line 0 starts before 4s, (some players won't show it)
01:35:06: subtitle duration: -1
01:35:06: ***************** HERE WE GO EVE.ODD *******************
01:35:06: MenuType: EVEN
01:35:06: subtitle_packet_size: 1900
01:35:06: subtitle_packet_size & 1: 0
01:35:06: subtitle_packet_size mod 2: 0
01:35:06: MenuType==""
01:35:06: MenuType=="EVEN"
01:35:06: final subtitle_packet_size: 1900
01:35:06: max_sub_size=1900
01:35:06: skipped 0 bytes of garbage
01:35:06: 1 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.18
done.
01:35:06: Encoding menu...Done.
01:35:06: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
01:35:06: -->: DVDFolders creating table of contents
01:35:06: scanning Z:\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
01:35:06: scanning Z:\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_02_0.IFO
01:35:06: scanning Z:\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_03_0.IFO
01:35:06: -->: Creating menu for TOC
01:35:06:
DVD Folders: Processing C:\Program Files\BadgerIT\SVCD2DVD v2\menu\menu.mpg...
01:35:06:
01:35:06:
01:35:06: Finalising DVD...Done
01:35:06: Done: Authoring DVD Folders
thanks 4 lookin btw
I'm at work and don't have access to the program ATM, but try this - set the menu to encode to the duration of the audio. There should be a selection to do this under "settings". If that doesn't work, you could also try selecting to encode the menu audio to AC3, but I don't think that is your issue as you are in PAL territory. If you need more help with this I can check the exact labeling when I get home.
Dwight
- Herm Albright
trouble with SVCD2DVD menu selection highlighting
By bobarnett in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 4th Sep 2011, 14:59 -
SVCD2DVD Error when encoding menu??
By gsmb in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 23rd Feb 2011, 13:44 -
Really strange SVCD2DVD menu problem
By denali in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 4th Oct 2009, 11:41 -
SVCD2DVD Vista problems
By blondeguysteve in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Nov 2007, 09:35 -
SVCD2DVD 2.5 Problems
By mistalcote in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 18th Aug 2007, 03:31
