  1. Hi, I have a problem with Dual Layer encrypted DVD... How to remove protection? I've tryed with some tools like DVD Decrypter, ShrinkTo5, Magic DVD Copier and some other tools, but nothing works. When I try to rip the movie, it gives me only 42 minutes of the file, I think because of layers... Help please!
  2. Member lacywest's Avatar
    Aug 2001
    California
    DVD Decrypter is old ... need the newer stuff to do the job ... right
    Boulder, Colorado
    When you ask for help about a certain movie, you need to list the movie what you are having trouble with. It might further help if you include what Region as in R1, R2, R3 etc, that certain movie is made for. Now for your potential answer. if DVD Decrypter does not allow you to make a successful backup, then you have NEWER and updated software like AnyDVD , RipIt4Me with FixVTS , or even DVDFab Decrypter among others. Dual Layer DVD does not indicate it is protected, just means it has up to 8.5 gigs of data.
  4. Thanks for the answer, the movie is Mirror Mask - R2. For now I will try with AnyDVD, if nothing happens - I'll post here...
