I found some dvds when i put the first one in my dvd player, a msg "check your region...." i assume that this dvd was coded in PAL am i wrong, how can recode or convert into something i can play in my dvd player, is there any software i can use?
the other dvd is also in dvd-r, when i try to play it, the dvd prompts "check your tv set, whats the problem here..?
i could play both dvd's in other dvd player but i dont remember if it was multizone
thnks in advance
konig
Results 1 to 12 of 12
both are burned discs, since i can t get the comercial version i need to convert,any help??
Get a good dvd player, region free,pal to ntsc conversion, and get those only released in uk via amazon, very efficient, also
http://www.sanity.com.au/DEFAULT.ASP?SHOWHMVPOPUP=Y
have some stuff not sold in any other country.
I have dozens of dvd's bought that way, use a philips dvd 727 or 642 player hacked to region free, or get an oppo which most rave about.
Why oh why do conversions.PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
i dont have enough "stuborn" dvd s to buy a multizone dvd player, i m sure there some kind of ware that will dot the trick. but nobosy has replied why the 2nd dvd asks me to check my tv set
you could rip them on your PC and convert them, then there wouldn't be any problems
rip them and watch them on the PC, if they are something you want to keep, convert them and burn them -
THE Individual VOBS plays in my pc, so how i must rebuild the dvd, i think there mus be a software to do that. do you mean that i put every file in a folder and burn a new dvd?
You can also buy a Cyberhome 300 clone at WalMart for $25-30 and make it region-free in 2 minutes in addition to ability to watch PAL DVDs on NTSC TV. That's what I did.
HI,
Who can help to convert my DVD(shit!) Bellagio P807 to multizone????
For other models I can help.
See all operations for some DVD players models on:monitor.espec.ws/section11/topic14245.html
DVD Region problem
By elty in forum Newbie / General discussionsReplies: 3Last Post: 12th May 2011, 10:39 -
region 2 dvd problem
By aprilluis in forum DVD & Blu-ray PlayersReplies: 0Last Post: 22nd Mar 2010, 19:47 -
LG RH2T80 Region code problem
By Travel Ted in forum Newbie / General discussionsReplies: 0Last Post: 23rd Jul 2009, 07:04 -
Problem with Region settings
By paulgold in forum DVD RippingReplies: 11Last Post: 18th Apr 2008, 22:47 -
Region problem with Pioneer
By bltprf in forum DVD & Blu-ray WritersReplies: 10Last Post: 28th Jan 2008, 05:36
