I have pretty much got the hang of making vcd's but always see that the ones i create are very pixelated when viewed on a big screen tv even a standard 20 inch tv
however i have downloaded some pre encoded media off of sites like morpheus for instance live various music videos and I have burned them and found them to be far superior than my home videos when burned on vcd and i want to know how to get the tightest picture on vcd
ps my dvd player doesnt support svcd
also if you have no suggestions just negative comments please dont reply
you try different things. if they dont work then try other different things.
there is no super secret to making VCD's that someone can tell you and miraculously improve your quality. hardware, software and technique all have a bearing on your final output. basically it goes something like try something new, burn, not happy, try something else new, burn not happy, try yet again, burn still not happy. you do that enough and eventually you will be able to create outstanding VCD's.
remember your attempt was only a failure if you don't learn from itpeace out,
dumwaldo
AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose. -
hey look not one single other reply.... could that possibly be because this is a STUPID question from a STUPID person. your Private Message calling me rude and telling me that i didn't offer you any help was an insult and to see that you edited your post to make derogatory comments here as well is a challange to show you your own stupidity.
what i said in my last post was the most practical advice that could be offered for such a clueless and uneducated question. i was even so kind as to offer some words of inspiration and let you know that if something doesnt work dont feel as if you have failed.
NOPE the reply wasn't good enough for you though because your reading comprehension level is to low to even comprehend the words i have strung together previously if you are under the impression it was insulting.
now if you have a question and are willing to hear answers then ask but if your gonna be a little bitch about it then STFU and dont bother asking for help because it is obvious you lack the intelligence to understand help when it is offered.
people like you amaze me. i guess you just can't fix ignorance.
foad,
dumwaldo -
Hopefully your DVD player supports CD-RW, like mine does.
Then like he said, try somthing, if it sucks, try somthing else. I got fair quality from the guides, and now I have gone off in left field, and done other things that im my opinion looks better to me.
Experiment.
VCD to VCD back-up
By fiiido in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th May 2011, 12:39 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
