So here is the thing, The file is already in XVID format, im using VobSub subtitles. I already finished one and it comes out working perfectly fine. But my question is that, since it is already in XVID format, all i want to do it just add in the subtitles, i do not need to encode it into XVID format. Is there a way, i can just add in the subtitles with out any compression or encoding? ( i am assuming encoding means converting the file into xvid or divx)
Otherwise, the program is great! does what i need it to do.
Here are the details from the log window. It took 1 hour and 22 minutes!!!!!! zzZzz
Thanks for your help.
[2/4/2007 5:21:32 PM] AutoGK 2.40
[2/4/2007 5:21:32 PM] OS: WinXP (5.1.2600).2
[2/4/2007 5:21:32 PM] Job started.
[2/4/2007 5:21:32 PM] Source resolution: 624x336
[2/4/2007 5:21:32 PM] Source fps: 29.97
[2/4/2007 5:21:32 PM] Output will contain 103710 frames
[2/4/2007 5:21:32 PM] Preparing subtitles for preview.
[2/4/2007 5:21:32 PM] Job finished. Total time: 0 seconds
[2/4/2007 5:22:07 PM] AutoGK 2.40
[2/4/2007 5:22:07 PM] OS: WinXP (5.1.2600).2
[2/4/2007 5:22:07 PM] Job started.
[2/4/2007 5:22:07 PM] Input file: C:\Documents and Settings\s14\Desktop\Soulmate Ep.01.avi
[2/4/2007 5:22:07 PM] Input codec: XviD
[2/4/2007 5:22:07 PM] Source duration: 57mn 40s 461ms
[2/4/2007 5:22:07 PM] Output file: C:\Documents and Settings\s14\Desktop\Soulmate Ep.01_agk.avi
[2/4/2007 5:22:07 PM] Output codec: XviD
[2/4/2007 5:22:07 PM] Audio 1: 192 Kbps AC3 2ch
[2/4/2007 5:22:07 PM] Subtitles: from external file: C:\Documents and Settings\s14\Desktop\Soulmate Ep.01.srt
[2/4/2007 5:22:07 PM] Format: AVI
[2/4/2007 5:22:07 PM] Target size: 746Mb
[2/4/2007 5:22:07 PM] Audio 1 settings: Auto
[2/4/2007 5:22:07 PM] Started encoding.
[2/4/2007 5:22:07 PM] Source resolution: 624x336
[2/4/2007 5:22:07 PM] Source fps: 29.97
[2/4/2007 5:22:07 PM] Analyzing source.
[2/4/2007 5:36:42 PM] Source is considered to be interlaced.
[2/4/2007 5:36:42 PM] Output will contain 103710 frames
[2/4/2007 5:36:42 PM] Demuxing audio.
[2/4/2007 5:37:06 PM] Preparing subtitles.
[2/4/2007 5:37:06 PM] Audio1 size: 83,042,987 bytes (79.20 Mb)
[2/4/2007 5:37:06 PM] Overhead: 576,768 bytes (0.55 Mb)
[2/4/2007 5:37:06 PM] Video size: 698,617,941 bytes (666.25 Mb)
[2/4/2007 5:37:06 PM] Running compressibility test.
[2/4/2007 5:41:01 PM] Duration was: 3 minutes 54 seconds
[2/4/2007 5:41:01 PM] Speed was: 22.12 fps.
[2/4/2007 5:41:01 PM] Compressibility percentage is: 76.24
[2/4/2007 5:41:01 PM] Chosen resolution is: 624x336 ( AR: 1.86 )
[2/4/2007 5:41:01 PM] Predicted comptest value is: 76.24%
[2/4/2007 5:41:01 PM] Running first pass.
[2/4/2007 6:05:18 PM] Duration was: 24 minutes 17 seconds
[2/4/2007 6:05:18 PM] Speed was: 71.16 fps.
[2/4/2007 6:05:18 PM] Expected quality of first pass size: 76.70%
[2/4/2007 6:05:18 PM] Running second pass.
[2/4/2007 6:44:42 PM] Duration was: 39 minutes 23 seconds
[2/4/2007 6:44:42 PM] Speed was: 43.87 fps.
[2/4/2007 6:44:42 PM] Job finished. Total time: 1 hour, 22 minutes 35 seconds
Yes you do. If you burn the subs into the video, it needs to be reencoded. It doesn't matter is everything else is still the same, resolution, codec, audio, settings, it still has to be completely reencoded.
audio sync with AGK
By coeng73 in forum Blu-ray RippingReplies: 16Last Post: 3rd Oct 2013, 15:13 -
AGK Batcher v1.01 Released
By OneAmp in forum DVD RippingReplies: 13Last Post: 24th Nov 2010, 10:35 -
Replacement for AGK?
By OldAmateur in forum Video ConversionReplies: 2Last Post: 1st Aug 2010, 16:47 -
AGK conversion problems
By loninappleton in forum SubtitleReplies: 10Last Post: 9th Sep 2009, 11:48 -
If you have plenty of time with AGK?
By aslan in forum DVD RippingReplies: 4Last Post: 29th Dec 2007, 15:36
