I've recently been having problems with Windows Media Player freezing my computer when video is played. It only works if I turn the hardware acceleration way down. I did research and found that the latest drivers for my video card (GEForce 6600gt) are conflicting with the motherboard (MB GIGABYTE GA-K8NS Ultra-939). Apparently I need to update the driver for my motherboard. However, I have no idea what to download. I found this page but I'm lost from there: http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1839
I have no idea what chipset, LAN or Raid mean. Can someone help me out?
If you're having conflicts with your video drivers then you'll need to download the video drivers from the GIGABYTE website.
At the GIGABYTE link you provided you need to download from the CHIPSET section:
NVIDIA Chipset driver for nForce3 series (Included LAN driver)
O.S. : Windows 2000,Windows XP This is the one you need to download. You can always not install the LAN driver which is your network ethernet connection that's built into your motherboard. Or you can install it as well. I believe you'll be given the opportunity to choose what drivers you want to install. LAN connection is what you use to get on the internet. For example if you have cable modem or dsl connection you would use that LAN connection to connect your cat5 cable to it. -
The date on that drive is 2005/05/26. I would guess it's the same version as the one on your motherboards installation cd disk, but maybe not. It shouldn't hurt to try it out.
Just download it to your computer, exit all your programs and run it to install. The program will ask to reboot when its finished so let it.
Good luck. -
Excellent. I just downloaded it and it solved the problem. Thanks, Budz and Scorpion King.
Updating Driver
By skorpinok in forum ComputerReplies: 0Last Post: 27th Jun 2011, 23:03 -
Windows XP Activation kicked in, was updating firewire driver.
By vhelp in forum ComputerReplies: 10Last Post: 28th Dec 2009, 19:33 -
Downloading Motherboard Upgrades to my Motherboard
By orfajackson in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2009, 16:54 -
Editing and updating
By Jomapil in forum FeedbackReplies: 2Last Post: 15th Feb 2009, 06:35 -
updating DivX from 4 to anything else ...
By HJSis1 in forum ffmpegX general discussionReplies: 2Last Post: 9th Aug 2007, 19:30
