moin, moin...
This is my first ask for help here and I hope,
my Denglish is understandable :)
I use to capture Music-Video-Clips from some
of our German stations using VDub and than I
convert them to MP3 and MPEG1 using TMPgenc.
I don't really care about the logos in the
corner, but now, one of the stations got the
crazy idea of running 2 horizontal scroll-
texts at the bottom of the screen.
Guess what ?
Yes, I want to get rid of them ;)
So my first ask for an advice is about the
easiest way to kill them. I would prefer a
VDub-Plugin as I already have to do some
cutting with VDub.
My second question might not be solved by a
free utility, but I just hope ;)
For MP3s I use ID3-Tags (and attributes under
BFS) to easyly keep infos about the song.
As far as I know, ID3-Tags can't be used with
MPEG1, so I got the idea, to replace the above
mentioned scrolltext by a discreet one of my
own, which may contain the data.
Or a "standing" text, but I have to test, if
it would only be ok at the start or whether it
will be ok through the whole clip.
Could one of these things be done with a plugin
for VDub.
Third and last point is fading.
Sometimes I can't cut correctly, no matter how
hard I try. Is there a batchable plugin, that
allows fade-in/-out for both, video AND audio ?
I dislike to use an additional program, as I do
mostly batches with VDub/TMPGenc and would skip
this idea, if it would break batching.
Oh...
...and I hope this was the right place to ask
and that I didn't overlook a FAQ/Howto/posting
that covers exactly my questions.
bis denne...
scholly
First of all, you may not be "very" successful in removing the scrolling text. You could try the DeLogo filter with VirtualDub, but since the text you want to remove is dynamic, your background may not blend properly.
However your idea of putting your own text looks fine. It will hide the blended background well. You can use the subtitler filter downloaded from the virtualdub site. There is an example SSA script which will help you add standing or scrolling text.
I am not aware of a FadeIn/FadeOut filter for virtualdub- though there may be one. If not, you could try Avisynth. -
moin, moin...
I've mostly solved it with plugins:
1. scroller away -> border control
2. logo away -> logoaway
3. own subtitle -> subtitler
4. own scroller -> subtitler
remaining issue:
I don't find a way to loop my own
scrolltext.
thanks for the help...
scholly
Lining up/replacing 2.0 with 5.1?
By digitalfreaknyc in forum AudioReplies: 0Last Post: 11th Aug 2010, 22:10 -
Menu replacing, is it possible?
By Instant Martian in forum DVD RippingReplies: 18Last Post: 11th Mar 2010, 13:04 -
Replacing subtitles
By tai in forum SubtitleReplies: 6Last Post: 30th Jan 2010, 11:20 -
Replacing MPEG audio.
By dfisher052 in forum AudioReplies: 3Last Post: 16th Oct 2007, 14:14 -
Replacing only a few of the subtitles
By fledermaus in forum SubtitleReplies: 11Last Post: 9th Oct 2007, 11:56
