I have a Panasonic DMR-E55 which I've had for almost three years It has developed a fault whereby it will not recognise DVD RAM discs which have been previously used in the machine stating that they are unformatted. It will not reformat these discs either. A separate machine used by my wife happily accepts these discs so there is nothing wrong with them per se. The really odd thing is that my machine will record onto DVD + discs still.
I am a primitive as far as technology is concerned and am baffled by this. Is my machine simply screwed?
Results 1 to 10 of 10
DVD-RAM uses a different wavelength laser than -R or +R.
It may be a fogged or dirty lens - or a faulty laser.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
Happened to me with a panny, just clean its lens. Its very easy to open it & clean it.
Wish I kept those disks though. sigh. -
Originally Posted by handyguy
what's the best way to clean the lens on a e55?
I have, and have used a Maxell DVD lens Cleaner Disc, after experiencing the Unformat message on some Panasonic Ram Discs. Funny, 90% of the discs that had problems were gold in color and have 2x-3x speed printed on the disc ( made in the US if I remember correctly). The white colored discs with no speed rating printed on the disc, but are stamped Made in Japan, have given me almost no problems at all.
Cleaning the Lens with the Maxell Disc, and wiping clean the discs themselves worked on the made in japan Ram, and did not work on the made in US Ram discs.
I think I just got my answer. I have burned maybe 2000 discs in the past 4 years, in PC burners, and Panny e10, e20, and e55 recorders. I almost never have a problem with any made in japan discs. Probably 800 - 4x-8x Taiyo Yuden, 4x Sony, 4x Maxell, and 1200 made in taiwan Verbatim 4x MovieReel discs. I will not use anything else. I guess made in japan is still worth something after all.
Oh well, so I'll stick to made in japan Ram from now on. AND, maybe Handyguy can tell me how to manually clean the Lens ( unless using a DVD Disc Cleaner is ok)Christian -
I don't use dvd cleaners. But Dry ones only get dust. Wet ones get oils.
I unplug it & unscrew the top, then take off the top of the dvd player part & clean it with a qtip dipped in alcohol. -
Panasonic DMR-EH50 and Pan. DVD-RAM disks inconsistent
By rehoboth in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Mar 2012, 21:50 -
picture control on Panasonic dmr e55
By mammo1789 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Jan 2012, 16:41 -
How to set correc IR (black level in panasonic dmr e55 and es15)
By mammo1789 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 13th Nov 2011, 09:42 -
Panasonic DMR E50/E55 drive replacement
By zzucru in forum DVD & Blu-ray RecordersReplies: 3Last Post: 7th Oct 2008, 13:09 -
Panasonic DMR-E55-E55S or E55K?1st DVD recorder/1st time posting
By ToeTagged in forum DVD & Blu-ray RecordersReplies: 7Last Post: 19th Jan 2008, 14:33
