Hi! I've been trying to choose an editing program for months. I've tried Sony Vegas, Adobe Premiere Pro, Canopus Edius. I have some problems importing clips with all these programs.
Sony Vegas:
When I import divx clip, it doesn't have sound.
Adobe Premiere Pro:
When I import divx clip, it has just sound, no picture.
Canopus Edius:
I cannot import divx clip at all.
In order to solve these problems I have used different codec packs like K-lite, ACE. I have tried to use simple codecs like divx, xvid. But the result is the same.
I tried Avid Xpress. There were no problems like that but it's to hard for my PC.
Please, help me solving the above problems!
Which program would you recomend to me?
Thank you in advance!
Divx should not be used for capture. It is designed for distribution after you are done editing.
Explain better your project flow.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Problems importing MP4/AVC video in Sony Vegas Pro 9
By mltwitz in forum Video ConversionReplies: 1Last Post: 30th Oct 2011, 14:57 -
Sony Vegas Pro - Importing clips from another project
By ClownInBrown in forum EditingReplies: 8Last Post: 18th Apr 2011, 20:43 -
Problems importing Quicktime movies into Sony Vegas
By matthewjohn23 in forum Newbie / General discussionsReplies: 8Last Post: 11th Feb 2011, 21:31 -
Sony Vegas or Editing programs
By nextoss in forum EditingReplies: 2Last Post: 13th Jan 2010, 15:00 -
Importing / Editting Edius AVI clips in premiere CS4
By Wael in forum EditingReplies: 2Last Post: 15th Jun 2009, 09:31
