hi there ,
just something that i cant figure out on which software to use.
i want to place multiple movies on 1 dvd. well i kind of know how to do using nero, but what i cannot do is have a menu so i can select which movie i wana play.
is there any easier software where u can place multiple movies on one dvd with menu.
i tried dvdlab but its kind of complicated. is there any other easier software.
pliz help
ConvertXtoDVD - simple, but much better and more reliable than Nero
Read my blog here.
WHEN USING NERO SIMPLY CLICK ON ADD MENU AND THEN YOU CAN SELECT THE MOVIE OF YOUR CHOICE.
Lawrence Johnson
Can you fit multiple movies on bluray media?
By rz514 in forum Authoring (Blu-ray)Replies: 12Last Post: 28th Apr 2013, 00:29 -
easiest method to convert movies with multiple m2ts files (seamless branch)
By zero7404 in forum Blu-ray RippingReplies: 3Last Post: 22nd Aug 2011, 09:10 -
choice: burn to single BD, or multiple movies in 264?
By jlm86 in forum Blu-ray RippingReplies: 15Last Post: 20th Feb 2011, 21:14 -
Converting Home Movies (multiple formats) to x.264
By llmercll in forum Video ConversionReplies: 12Last Post: 24th Nov 2010, 11:42 -
DVDLab pro -multiple movies-menu-objects-BTN number mismatch
By sumeshkri in forum Authoring (DVD)Replies: 11Last Post: 15th Jan 2008, 08:48
