I DID SOMETHING WRONG BY PUTTING IN THE REGION CODE. MY PICTURE STARTED SCROLLING. I TRIED TO REMEMBER THE STEPS AND LOST THE PICTURE COMPLETLY..
QUESTION: IS THERE A WAY TO RESET THE DVD.
THANK YOU FOR THE HELP
PETER
THANK YOU GUNSLINGER.
I'M BACK ON TRACK
PETER
Sounds like you switched the format to PAL along the way.
This is the closest to a reset I can find
Open and close the drawer with no disc.
Press the STOP button on the player for 5 seconds
Although some say 5 seconds isn't long enough, so hold it for 10 or more to be sure.Read my blog here.
Hopefully the reset works. But in case it does not, I was able to fix my DVD Player once when I accidentally changed the Format (I went from NTSC to PAL).
I have a couple of capture devices, so I hooked the DVD Player into my capture device, set switches and software to preview PAL, and was able to see the PAL screen on my computer -- this allowed me to use the remote control to go through the menu setup on the dvd player to set it back to NTSC.
Regards,
George
Protron DVD player PD-007 in Progressive mode How do I reset.
By joe347 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 25th Nov 2013, 21:36 -
How to reset the DVD drive region code?
By coody in forum DVD & Blu-ray WritersReplies: 13Last Post: 17th Apr 2010, 04:42 -
Frogot Reset password to play Panasonic DVD LS83
By ikecanada in forum DVD & Blu-ray PlayersReplies: 5Last Post: 25th Mar 2009, 00:36 -
Win XP - How to reset the DVD/CD burner?
By coody in forum ComputerReplies: 1Last Post: 8th Feb 2009, 00:15 -
How can I reset my Sanyo DVD player?
By 89SDML in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Feb 2008, 12:08
