Which resolution do you use? For me, Its 800x600 ALWAYS. Especially when using a laptop when a small screen.
I see other laptop users around my college, with resolutions like 1280x768, and i wonder how the hell they can stand to use them like that. Everything being so Tiny.
So which do you do?
Results 1 to 30 of 46
Hi,
I have a widescreen laptop and use 1920x1200, it'd drive you nuts!! If you have less than 20/20 vision it's pretty hard to see. -
1024 X 768 on most everything, including my laptop. If I had a 19" monitor, I would probably use a higher setting. Most all LCDs get the best quality at their native settings and that usually goes by the screen size.
I have friends with poor eyesight that prefer 800 X 600. which works better with CRT type monitors. I find most internet sites are sized for 1024 X 768, so that is another consideration. I've tried the 1280 X settings, but with a 17" monitor, still too small for me.
For those with desktops & LARGER monitors i guess i could understand using a smaller res.
But for a laptop with a small screen, I GOTTA have *800x600*. What good is having a higher resolution if its so tiny, that you CAN'T see anything clearly?
Maybe if you're a teenager and your eyes are still sporting near-perfect vision. Those 20 yrs old and over, forget it. -
15" 1024x768
19" 1280x1024Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
"Maybe if you're a teenager and your eyes are still sporting near-perfect vision. Those 20 yrs old and over, forget it. "
I'm 38 :-b -
laptop(15.4" widescreen): 1280x800
desktop(20.1" widescreen): 1680x1050
These settings are great for me, and I'm not a teenager, I'm 20 :P
my brothers laptop is a 15.4' screen with 1680x1050 resolution, and I do find that a little hard to see.
The fact that my desktop monitor is 20 inches makes the high resolution quite readable. -
Im approaching 40 myself , but dont have any issue's with any screen res used ... the higher the better ... so I can fit all my crap on the desktop for quick access on site .
I must have good eye sight when the younger generation has problem's ... lol
Look ma ... no glass's .
I just got to remember to wear those goggles when I do welding ... mig will fry the crapola out of anything unprotected .
Lets see ... 17" lcd + 17" crt + 19" lcd ... and one humunguous 23" crt ... it's not the sight problem ... it's that the damn thing's get heavier the bigger they get . -
19", 1280x1024
/Mats -
No choice for 1680x1050.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
1280 x960, I'd go larger but a lot of websites are using fixed font sizes which makes some of them impossible to read.
1280x1024 on 19" LCD
1920×1200 on 24" LCD widescreen
1440x900 on 17" LCD widescreen (laptop)Want my help? Ask here! (not via PM!)
17" CRT: 1152x864
21" CRT: 1360x1024, 1600x1200
20" LCD: 1680x1050
Most with larger than normal fonts. -
19 in ...1152 x 864
You get more on the screen at once, and bearing in mind some programs won`t run on 800 x 600 -
22" widescreen LCD @ 1680 x 1050
My current flat screen resolution is not listed, so here is it:
1440 X 900 (20" Widescreen flat screen)No tengo miedo a la muerte. Solo significa soñar en silencio. Un sueño que perdura por siempre. .. -
1280x1024
They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
I just bought a ViewSonic 19" LCD (model VX922) which has a native resolution of 1280x1024 so that is what I use now.
Before I had a Sony Trinitron CRT 17" and I used 800x600 at first then slowly changed to 1024x768 which took a bit of getting used to on that display (was a bit small) but I finally did. I actually preferred 800x600 on it but some programs wouldn't work right without the resolution being 1024x768 and that also applied to some website designs as well so I eventually got used to it.
Right now I am happy with the 1280x1024 of the 19" LCD although at first I thought the text was small ... but here I am barely 6 weeks later and I've adjusted.
I should point out though that I only use 1280x1024 because it is the native resolution of the LCD ... otherwise I might very well be using 1024x768 still.
My Laptop screen is 14", in case i have not mentioned it, and i am 25.Originally Posted by Grimey
Even at 800x600, i still sometimes prefer to wear glasses when on it. -
1024x768 on a 17" flat screen tube monitor. Works just fine for me personally. I don't need to go any higher or lower.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
1280 x 1024 on a 17 inch CRT.
1. 800x600, my god, not used that resolution for about 5 years.
2. Looking at stats from webpage visits to a few different web sites, 1024x768 still seems about the most popular though is closely followed by 1280x1024. I expect the 1280 will become the 'norm' during the year.
3. If you are going to run a poll, at least include all the popular resolutions. -
1024x768 on a 17" CRT
I find a lot of programs and websites are unworkable at lower resolutions.
If the fonts or other objects are too small at higher resolutions you can adjust them.
Right click on the desktop and look at "properties". -
1280 X 1024 on my 17" TFT
This resolution should be on the poll option since many people use it.
Going from high resolution photos to low resolution photos
By bryankendall in forum Newbie / General discussionsReplies: 7Last Post: 5th Jan 2018, 11:57 -
Encode video with different luminance resolution and video resolution
By kylix999 in forum Video ConversionReplies: 14Last Post: 6th Jun 2012, 07:57 -
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 06:36 -
Dynamic Resolution PC Monitors vs TV Monitors Static Resolution.
By therock003 in forum Newbie / General discussionsReplies: 24Last Post: 17th Apr 2009, 08:28 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 01:57
