Hi,
To avoid adio synch problems, I put AVI files through AVIMux_GUI to fix audio delay to 0 before converting the AVI into m2v. I am not sure whether it fixes all audio problems but I have been experienceing way less audio synch problems since I started doing the procedure.
I am wondering whether there is a way to fix audio delay to 0 in PAL DVD before converting it NTSC DVD. When I put the DVD through DGIndex I get a d2v file, a demuxed m2v file and a separate audio file that shows whether there is a delay. Is it possible to fix the delay?
Thank you!
Thank you, Baldrick.
Yes, it is ac3 file. I never heard of the tool. Definitely will give it a try.
Audio delay reported in MKV and what to do with it when adding new audio
By pascal in forum AudioReplies: 14Last Post: 30th Dec 2011, 11:07 -
Need help in fixing audio delay which builds up as the video goes on ..
By ahmadka in forum AudioReplies: 4Last Post: 29th Jun 2010, 09:56 -
Adding audio (wav) to video (avi) (want to delay start of audio)
By Lanton in forum Newbie / General discussionsReplies: 2Last Post: 12th Apr 2010, 12:50 -
video/audio delay
By cyber69 in forum Newbie / General discussionsReplies: 7Last Post: 3rd Nov 2008, 14:45 -
Audio delay.. can anyone help?
By denadel in forum AudioReplies: 5Last Post: 31st Dec 2007, 11:14
