Hi,
Longtime (seems like a long time anyway...) user here. I'll soon be selling ad placement on my site http://www.tornadohistoryproject.com, but don't really know how to go about doing it. I was just curious if Videohelp uses some kind of ad serving tool and, if so, what is it and would you recommend it?
Thanks.
Yep, I use www.phpadsnew.com . Free, easy and has many features....but I have never tried anything else so I can't really say if it's the best out there.
and I haven't updated it in some years as I just noticed that they have changed name....
.. but probably still much the same.
Thanks! I'll check it out. Since my site went live 1 or 2 months ago I've been using AdSense, but I'd like sell ad space directly to potential advertisers so that the ads are more in line with the subject matter.
I ran across the software Baldrick mentioned myself, basically trying to do the same thing you are. Just my .02 but I found it overly complex for a small site serving a few ads. I mean you can literally serve ads to hundreds of sites using that software. Anyhow a simple php script that serves ads one at time per page load shouldn't be that hard to find or make. Random would be easy (even I can write that :P ) but you'd want something that was going to track what was served so they were evenly distributed, probably require a database entry...
You can always try http://adspro.mhfmedia.com
Can you use frame serving for video conversions?
By johnharlin in forum Video ConversionReplies: 2Last Post: 2nd Mar 2011, 22:39 -
File serving programs?
By dvd mon in forum Video Streaming DownloadingReplies: 5Last Post: 25th Jan 2011, 06:01 -
Frame serving
By carlmart in forum Video ConversionReplies: 2Last Post: 2nd Jul 2009, 08:39 -
Vdub frame serving to CCE ?, UPDATE ..Fixed the Error
By theewizard in forum Video ConversionReplies: 15Last Post: 31st Jan 2008, 23:24 -
Western Digital network drives crippled -- no serving any multimedia files
By rkr1958 in forum Latest Video NewsReplies: 17Last Post: 13th Dec 2007, 02:57
