I have tried to add subtitles to an movie using the program "Avisubtitler" but when i finished the movie was without sound. How can i fix this problem ?
http://www.divxland.org/permanentsubtitling.htm
See how that works out for you . -
Thanks for the link.My other question is : If i have movie split on two parts what i should do first - to join the files and after that to add the subtitles or first to add the subtitles and after that to join the files ?
Yes ... what a pain that is ... oh , you want to know how ...
I actually prefer to split the subtitle for each half ... may even need to convert it for visualsubsync .
Get it aligned using visualsubsync , then save that out , then process second half .
How you want to join them is then another choice ... avi to avi (vdub or other) or avi to dvd (avi2dvd , other ... or my way).
This way there's no screw up with audio sync , or misalignment with sub in second half ... stuff I can do without .
That tool also mentions "Avi file must not contain errors" ... so if there's any internal problems in the avi , it might cause the problem you experienced ... gspot for checking internal info of avi's .
Was it the iphone that replaced the word "program" with "application"?
By yoda313 in forum Off topicReplies: 6Last Post: 16th Mar 2011, 08:52 -
Quality problem "caused" during "deinterlacing" ?
By Hombre_86 in forum DVD RippingReplies: 26Last Post: 25th May 2010, 21:28 -
Removing bad segments using program "Video Edit Master"
By risp73 in forum Newbie / General discussionsReplies: 0Last Post: 30th Aug 2008, 15:52 -
VirtualDub "Access Violation" Crash, Alternative Program?
By Ruro Jiruries in forum EditingReplies: 6Last Post: 29th Jul 2008, 16:16 -
Any Program to "blank out" or "black out" a portion of
By mbextreme in forum EditingReplies: 6Last Post: 18th May 2007, 04:04
