Hi and thank you in advance for your attention.
I downloaded an Avi file from the Net and I want to burn it to DVD including subtitles. It's an Xvid-encoded file and everything in my system seems to be OK: The latest version of the codec is installed properly, GSpot reports it with no problems and the file seems to be OK.
If I load the Avi file directly into TMPGEnc Plus, it is properly recognized and I can convert it to Mpg as expected. The thing is, I can't use that method since I want to incorporate subtitles into the movie, so I use VirtualDub's frameserver mode for that: Load the movie into VirtualDub (which is properly detected - no video or audio issues), load the Subtitler filter with the SubStation Alpha script, make sure that preview shows it fine and then create a Vdr file using the frameserver mode. When I try to load it into TMPGEnc plus, I receive a "...vdr can not open, or unsupported" message (again, this doesn't happen if I load the original Avi directly into TMPGEnc). I've tried changing settings of VFAPI plug-ins with no success. I highly appreciate your input on this. Thank you in advance!
Tried the TMPGEnc related tips found here?
https://www.videohelp.com/virtualdubframeserve.htm#problems
Quickly located by utilizing this sites search feature
/Mats -
Did you run AUXSETUP.EXE in the VirtualDub folder? That installs the frameserver handler for VirtualDub. TMPGEnc works fine with VirtualDub's (and all the variants) frame server.
Thanks for your replies! Here's what I've tried so far:
- Add ".avi" to the end of the file name. "filename.vdr.avi". Didn't work.
- "Copy this msvcr70.dll to your WIN/SYSTEM32 folder and restart VirtualDub". Didn't work.
- Readavs.dll vfapi plugin didn't work.
- Install the ProxyOn (frameserver handler). Already installed, but re-installed it. Didn't work.
- "If TMPGenc gives you an error when opening the video.vdr.avi click on Option->Environmental settings. And this window appear, click on VFAPI plugin and right click on the DirectShow Multimedia File Reader and select Higher priority". Didn't work.
I've encoded frameserved movies before using VDub and 99% of them work fine. This problem already happened before with other movies (2, I think) but since I didn't plan to put subtitles, I just used TMPGEnc plus directly to encode them. No problem. But now I need the frameserver and it doesn't work in TMPGEnc with this particular file.
Thank you again for your replies! -
Hey! I've just uploaded to the Net a short avi file (2min. 14 secs., 16.54 MB) which shows exactly the same behavior as my movie. I really appreciate it if some of you take the time to download it and test it (convert it to a DVD-compliant file -individual elementary streams since I use CBR linear PCM audio- with TMPGEnc Plus through VirtualDub's frameserver mode). Everything is fine with the file: VirtualDub opens it with no errors and same for TMPGEnc if loaded directly, but when I try to open the vdr file from VDub, the error appears. Here's the link for downloading the file:
http://download.yousendit.com/57B50B927C630CFB
This link is supposed to work as well:
http://www.yousendit.com/download/THE0c2ZIT2JVVGw1VEE9PQ
(The links will be available for the next 14 days or 500 downloads)
Thank you in advance for your time! -
I downloaded the fiest file, opened it in VirtualDub 1.6.15, frameserved to TMPGEnc Plus 2.521.58.169, converted to MPEG with no problems at all. Did the same with VirtualDubMod 1.5.10, same result. I'll try again later with some SRT subs.
I used the TextSub filter to add SRT subtitles -- saving as Xvid AVI went fine. When frameserving to TMPGEnc, TMPGEnc crashed when opening the file -- no error message, the window just closed.
Looking at the frame size of the AVI file, 640x270, I guessed that might be a problem. After resizing to 640x272 everything went fine. -
Originally Posted by jagabo
AVI won't play. VLC say's doesn't support "IV50" Format. All codecs present
By Sikander in forum Software PlayingReplies: 2Last Post: 21st Feb 2010, 07:40 -
Firefox3 doesn't support realplayer plugin
By toddfv411 in forum Video Streaming DownloadingReplies: 4Last Post: 9th Jun 2008, 18:27 -
Only TMPGenc Support .vdr
By arturjose in forum Video ConversionReplies: 1Last Post: 15th Apr 2008, 23:04 -
After reinstall of OS etc, Tmpgenc encoder can't support avi media files
By AORMan in forum Video ConversionReplies: 15Last Post: 2nd Feb 2008, 10:36 -
How can I install PPro2 on system that doesn't support SSE2?
By Sean_ve99 in forum EditingReplies: 1Last Post: 26th May 2007, 07:33
