Hi, my harddrive crashed that had my operating system on it, but i have a 2nd harddrive that has a folder that had encryption from windows xp, and 1 folder that had encryption from 'lock my folder 1.0"
i didnt save any of the keys or anything from the orignal windows installation. how do i remove the encryption from the windows xp? and from the 'lock my folders'?
thansk!
Depend's on who your talking about here .
http://www.qksoft.com/lock-my-folder/how-to-unlock.html
Xp encryption removal : http://support.microsoft.com/kb/308993 -
If you didn't save the keys, this is probably your only hope to decrypt XP encryption >
Advanced EFS data recovery software
http://www.elcomsoft.com/aefsdr.html -
i think the
Advanced EFS data recovery software is what i am looking for.
thanks!
after the folder is decrypted will i be able to remove the encryption all together?
Do you know about, how long it can take to decrypt a file? and then a folder with 1GB?
And if all the files have the same encryption, will it memorize the ecryption key? (so i dont have to process every file? -
Once you have found and entered encryption key you can do everything you could do before to the folder.after the folder is decrypted will i be able to remove the encryption all together?
Sorry, thankfully never had to use it, so I don't know how long to takes to search. -
Depending on the type of encryption and the number and size of the files, as well as the speed of the PC, this operation could take days to complete.
This will give you sufficient time to kick yourself in the ass several dozen times for not keeping a seperate copy of the encryption keys. If you are not flexible enough for this, virtually anyone you tell this story to would be willing to do it for you. -
Hi Nelson,
I saw some of your posts in "How to rip closed captions from a DVD?" and I got particularly interested in the application, you created, called ATI2SRT.
I tried to get in touch with you through PM and post in the topic but I got no reply.
I know this this not the place to post for this, but I thought this was the only way of reaching you.
Could you send me the ATI2SRT to my e-mail? I would really appreciate it?
My e-mail is: ricardovas@yahoo.com
Thanks and sorry for any inconvenience. -
Hi Nelson,Originally Posted by Nelson37
batch dvd ripping - output folder to input folder?
By mkv2avi in forum DVD RippingReplies: 5Last Post: 17th Apr 2012, 16:23 -
Wgat would be the proper folder structure to add movie cover to a folder
By VoodooEvil in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2012, 19:09 -
WPDNSE folder inside your system Temp folder????
By MozartMan in forum ComputerReplies: 25Last Post: 27th Mar 2011, 08:35 -
Win 7 folder options?
By jyeh74 in forum ComputerReplies: 8Last Post: 21st Jan 2010, 15:43 -
removing CSS from a video_ts folder?
By ehmjay in forum MacReplies: 23Last Post: 29th Feb 2008, 20:15
