I've just burned my DVD movie, and it plays OK on my computer.
Everything looks in the right place.
However, when I go to play it in a DVD player, the picture is off-centre (to the left).
I am in the UK using PAL.
Is there a way of rendering it to make 100% sure that it display properly in my DVD player?
Also the DVD will be played by some people in the US... any comments?
Tks,
Sony DVD Architect 3.0
I think you'll have to explain in more detail what and how you've gone about this.
One thing that may manifest itself like this, is when you use a non DVD standard frame width. (352, 704 or 720).
For US use, you have to create a DVD to NTSC standards. NTSC will play fine on most PAL equipment, but best would be to create 2 versions.
/Mats -
Thanks Mats, I think I was using a non-standard frame.
The default one is 720x480. What is the standard DVD frame settings?
I would like a good quality as the movie is just 10 mins long.
What settings would you suggest I use, and would these settings look equally as good played in a DVD player and through a laptop/desktop?
Tks -
720 x 480 is NTSC. Your player is probably playing OK, however your TV might not be happy with the output if your player isn't outputting true NTSC. Some players do half-arsed conversions by default. Make sure your player is set to output NTSC format if the source is NTSC, and not pseudo-PAL. Otherwise you will have to convert the video the PAL, which may give you other issues.
Read my blog here.
Blu Ray Player Vs DVD Player upscaling picture
By mukeshs in forum DVD & Blu-ray PlayersReplies: 10Last Post: 10th Dec 2010, 03:21 -
Only picture and no audio coming from DVD player
By sulentho in forum DVD & Blu-ray PlayersReplies: 6Last Post: 11th Jul 2010, 23:44 -
DVD player is getting power but I can't get any sort of picture
By Rhiannon in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd May 2010, 22:33 -
Recode DVD or use DVD player to upscale? For Best picture on HDTV
By hellbringer in forum DVD RippingReplies: 10Last Post: 4th Oct 2008, 22:27 -
Sound but No Picture in DVD Player using DVD+RW
By mrnader in forum DVD & Blu-ray PlayersReplies: 2Last Post: 27th Aug 2007, 21:24
