If I have a DVD, is there some way for me to verify what region it is? ie. 1,2,3,4,5,6,0 and also PAL or NTSC. There must be some kind of software out there that does this. I find that many times what is listed on the box is not accurate.
You could try MediaInfo or look for some other similar programs in https://www.videohelp.com/tools?s=38#38 Software players like PowerDVD may also give you the information you need.
Other members may have better suggestions.
And welcome to our forums.
DvdInfo , DVD Decrypter can check region coding.
AVIcodec , GSpot can check the "frame rate" which should tell you the format, PAL or NTSC.
LG ht904ta dvd player regional free code
By Mwilamj in forum DVD & Blu-ray PlayersReplies: 1Last Post: 7th Nov 2010, 01:49 -
Regional Code Question - Insignia DVD player - can't play DVD I ordered..
By LadyDriver22 in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2010, 13:08 -
LG HT963TA DVD regional code unlock?
By Reasoner in forum DVD & Blu-ray PlayersReplies: 0Last Post: 24th Jan 2010, 21:54 -
How to set the regional code for Philips DVP3146
By funnymummy in forum Newbie / General discussionsReplies: 4Last Post: 17th Apr 2008, 08:35 -
Durabrand ADB2737BDS changing regional code problem
By Natasha101 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 7th Apr 2008, 14:12
