Im trying to back up a dvd for a car-copy using dvd decrypter. Ive never run into this problem before. Ive uninstalled and re installed my programs and rebooted and am still having the same issue. As you will see there was a problem with the size, which I overrode. I would think that it was a bad disc, but Ive added 3 coasters to my collection so far, and tried so many things! Im hoping someone can help me. Here is my log:
I 13:59:06 DVD Decrypter Version 3.5.4.0 started!
I 13:59:06 Microsoft Windows XP Media Center Edition (5.1, Build 2600 : Service Pack 2)
W 13:59:06 Drive D:\ (FAT32) does not support single files > 4 GB
I 13:59:06 Initialising SPTI...
I 13:59:06 Searching for SCSI / ATAPI devices...
I 13:59:06 Found 1 DVD±RW!
W 14:00:14 User accepted disc space warning and is attempting to overburn!
I 14:00:14 Operation Started!
I 14:00:14 Source File: C:\THE_GUARDIAN.ISO
I 14:00:14 Source File Sectors: 2,299,280 (MODE1/2048)
I 14:00:14 Source File Size: 4,708,925,440 bytes
I 14:00:15 Source File Implementation Identifier: DVD Shrink
I 14:00:15 Destination Device: [0:1:0] PHILIPS DVD+-RW SDVD8820 AX03 (E(ATA)
I 14:00:15 Destination Media Type: DVD-R (Disc ID: TTH02) (Speeds: 2x, 4x, 6x, 8x)
I 14:00:15 Destination Media Sectors: 2,297,888
I 14:00:15 Write Mode: DVD
I 14:00:15 Write Type: SAO
I 14:00:15 Write Speed: MAX
I 14:00:15 Link Size: Auto
I 14:00:15 Test Mode: No
I 14:00:15 BURN-Proof: Enabled
E 14:27:17 Failed to Reserve Track! - Invalid Field in CDB
E 14:27:21 Operation Failed! - Duration: 00:27:06
I 14:27:21 Average Write Rate: N/A - Maximum Write Rate: N/A
PHILIPS DVD+-RW SDVD8820 AX03 (ATA)
Current Profile: DVD-R
Disc Information:
Status: Empty
Erasable: No
Free Sectors: 2,298,496
Free Space: 4,707,319,808 bytes
Free Time: 510:48:46 (MM:SS:FF)
Supported Write Speeds: 2x, 4x, 6x, 8x
Pre-recorded Information:
Manufacturer ID: TTH02
Physical Format Information (Last Recorded):
Book Type: DVD-R
Part Version: 5
Disc Size: 120mm
Maximum Read Rate: Not Specified
Number of Layers: 1
Track Path: Parallel Track Path (PTP)
Linear Density: 0.267 um/bit
Track Density: 0.74 um/track
First Physical Sector of Data Area: 196,608
Last Physical Sector of Data Area: 0
Last Physical Sector in Layer 0: 0
HappyMomm,
Your problem is this:
What you're trying to burn is larger than the capacity of the media you're burning to. You need to reduce the size of the material you're trying to burn, either by blanking unwanted items with VobBlanker, or (re?)transcoding with DvdShrink (or CloneDVD, or whatever you use).Source File Sectors: 2,299,280
User accepted disc space warning and is attempting to overburn!Yes, I see that. Unfortunately, the problem still existed. Even if you could get a dvd to overburn, it would be out of spec, and almost certainly wouldn't work in a dvd player. Some software warnings you can ignore, some you can't.As you will see there was a problem with the size, which I overrode.
It's not connected to your current problem, but it would be a good idea to change your burning program from DvdDecrypter to ImgBurn. The same author did both programs, but ImgBurn is much newer (improved), and doesn't require the use of an ISO.
I see this was your first post, so welcome to VideoHelp.
Lower field first/upper field first/progressive/de-interlaced?
By John Nada in forum EditingReplies: 7Last Post: 2nd Sep 2011, 04:12 -
Invalid Public Atom
By Michael Boutros in forum ffmpegX general discussionReplies: 3Last Post: 22nd Apr 2009, 13:26 -
upper field or lower field first? how should I export from premiere
By phpmysql348 in forum EditingReplies: 2Last Post: 6th Sep 2008, 23:54 -
Top Field First to Bottom Field First
By boblin2 in forum Video ConversionReplies: 0Last Post: 6th Dec 2007, 00:19 -
Invalid Location
By Justgrant2009 in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2007, 19:48
(ATA)
