  1. Hi All,
    I just installed a fresh copy of ffmpegX and it works fine and so fast on my new Core2Duo 2Ghz Macbook.
    I encoded some flv file to put on my website.
    It appears that the progress bar and sekking function cannot work because the flv file doesn't contain any metadata.
    Is there a fix for ffmpegX (mencoder) ?
    If not, is there a piece of software that can easily solve my pb ?
    Thanks,
    LoLoVioLo
  2. Yes, you should run FLVTool2 on the FLV file http://inlet-media.de/flvtool2 which I'm going to add to the next version.
