Results 1 to 16 of 16
If the A/V sync is good in the originals, and you can play them in QT Player, try MPEG Streamclip to encode to H264. It's a good alternative; let's call it another tool in your toolbox.
Thanks for the reply.
Yes the A/V sync is god in the original and it plays fine in QT.
Thanks for that suggestion, but i need a program with subtitles support and MPEG Streamclip doesnt support :/
The strange thing is that ffmpegx worked before and after a reboot it doesnt work anymore..
Where does the AV sync problem arise? During the mencoder encoding (to include the subs) or afterwards, when going to H264?
A-ha! I thought (erroneously) you were going to H264 for iPod (which requires a separate encoding in order to do the embedded subs).
I don't have a snap-of-my-fingers solution for you but, as a workaround, you might try embedding the subs first keeping the quality max'd with DivX or XviD and, if the resulting file is in sync, then do the H264 transcoding. You shouldn't lose any quality.
I'm having a similar problem trying to convert a 1 min .mov to .avi Divx (using the presets)
The .mov file is fine in QT, but played in mplayer, the audio's out of sync with the video. The resulting .avi is exactly like the out-of-sync clip that plays in mplayer.
The source format says from mov, video qtrle, rgba32, 848x477, audio adpcm_ima_qt, 22050 Hz, mono
Thanks for offering to helpin the options tab
On my option tab I have mencoder DivX options: high quality, use b-frames, 4 motion vectors, two-pass encoding, three-pass encoding, trellis quantization, quarter pixel ME (qpel), but nothing about quicktime.
If I select divx ffmpeg instead of divx mencoder, the decode with quicktime appears. But then the encoding fails (I cannot even play the source movie with the play button).
version 0.0.9x r2
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 13:13 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
How to sync video with audio
By Denster in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 21st Apr 2010, 22:25 -
Best way to sync audio/video for part of a video
By marioval in forum EditingReplies: 2Last Post: 19th Mar 2010, 13:30
