hi all . i try to make dvd using adobe encore 1. But when i import a captrued mpeg2 file i get the following error:
Could not import file bic.mpg.
Video files for this project must have a resolution of 720X576 or 704X576
could any one tell me how to fix this problem.Thanks
Can you post the details of your mpeg2 files? You can identify the resolution with latest gspot or mediainfo. The mpeg2 files must be 720x576 or 704x576 if you are making a PAL DVD with Adobe Encore.
baldrick the following is infor about one of the file:
C:\Program Files\Pinnacle\MediaCenter\Capture\Video\dvd\gumra h song1.mpg
File : 149 MB (0.00 B), duration: 0:00:00, type: MPG, 1 audio stream(s), quality: 57 %
Video : 0.00 B, 3675 Kbps, 25.0 fps, 352*576 (0.61:1), MPG2 = MPEG 2 (SVCD/DVD), Supported
Audio : 0.00 B, 256 Kbps, 48000 Hz, 2 channels, 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported
When i used pinnacle studio plus to make dvd it did not complain and it created the dvd!! now i want to use it in encore i get in to this problem. Is there a way to fix it?Thanks -
352x576 is a valid dvd resolution but adobe encore doesn't support it anyway. But why not capture in 720/704x576? Or switch to another authoring tool like tda, dvd-lab.
Problems editing 'studio quality' MPEG2 with Adobe
By KevinCease in forum EditingReplies: 31Last Post: 27th Feb 2015, 21:05 -
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 16:25 -
MPEG2 Encode - Scene Change Detection (Apple Compressor vs Adobe vs other)
By rallymax in forum EditingReplies: 7Last Post: 21st Jan 2011, 19:44 -
Probable Codec problem. No audio on MPEG2 muxed files
By Kevlin in forum MacReplies: 14Last Post: 17th Apr 2010, 03:05 -
problem using youtube avi files in adobe after effects 7
By method in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2007, 23:26
