I have some problems with divx files. R135 can play some of the .avi files, but not all of them. For those having problems, it shows a lot mosaic on screen. I can play those files on PC w/o any problem.
Another issue is how I can choose srt files on R135 if I have several srt files associated w/ .avi file.
Check the files using the latest gspot, it will tell you the codecs used for the file. You will see that the files that don't play properly are different than the ones that work. Basically, you will need to reencode the files that don't play properly to make them compliant with your player.
I'm not familiar with the R135 and subtitles. You may have to choose the sub title file first (highlight subtitle file and press subtitle button?) and then highlight and play the video file.Google is your Friend
DVD-R135 Display shows “SAFE”.
By audio_3950 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 4th Dec 2009, 15:04 -
Need some Feedback: Philips DVDR3475/37 and Samsung DVD-R135
By BrokenOne in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Dec 2007, 00:58 -
Samsung HT-TX75 not playing my Divx & Xvid files
By danimaltron in forum DVD & Blu-ray PlayersReplies: 7Last Post: 19th Nov 2007, 21:02 -
Dr. DivX converts large VOB files into tiny unusable divX files
By texas1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2007, 22:44 -
Samsung DVD-R135 code hack
By stasioau in forum DVD & Blu-ray RecordersReplies: 8Last Post: 6th Jun 2007, 17:16
