OK I have a 3pk of MEmorex DVD+R DL Disks. I used DVDDevrypter to rip a DVD9 movie, and IMG Burn to burn it to my DL Disk. The burn went perfectly. Now I have 3 DVD Players(1 4yr old one, A new Panasonic S52 which can specifically play DVD+/-R DL, and a PS2). So I took my new burn , and played it in my oldest DVD Player to ensure compatibility. I played through perfectly until about thje last 1/4 of the movie. I then started to see very tiny flashes and artifacting very intermitently. They do not happen in the same spot, for when I rewind and play a certain spot over, they do not appear but rather appear a few seconds before of after. As far as playback went there was no jumping/skipping(except for the layer break.
Now my other 2 DVD Players(new Panny and PS2) did not have this problem. Is it safe to assume that the onyl reason O got these slight artifacts in the video was because the older player was having problems reading the disk?
-Zero
I would venture to guess that your guess is probably accurate.
I would scan the disk surface with DVDInfoPro to see if shows any anomalies in that general area. -
zero83,
I would also agree that your analysis of the problem is a good one. You would probably get better results, in the long run, by using Verbatim +R dual layer disks.
VHS-C playback issue, playback in B&W and distorted/noisy colour.
By jpoel in forum Newbie / General discussionsReplies: 4Last Post: 11th Aug 2010, 10:36 -
DVD Backup - erroneous playback on dvd player althought perfect on the pc
By RedBolt in forum Authoring (DVD)Replies: 3Last Post: 12th Jun 2010, 00:00 -
DVD to storage drive, best media player for dvd playback- newbie questions
By omkls08 in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2009, 11:22 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 10:19 -
DVD+/-RDL Playback on Yamaha DVD-C750, DV-C6770, and DVD-C950
By Big C in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2007, 09:59
