I just purchased the Samsung DVD-HD90, I am having a problem playing some of my DVD+Rs. I have noticed it is the ones I had to run ANY DVD in the background to copy. Would hacking the DVD player and making it capable of playing all regions solve this problem?
No. If it was a region issue, the disc would not be playable and you would get an invalid region error or something similar. Most likely, it is a media issue. Your new player may not like the brand/type of media that you are using. You can try looking up your player in the DVD Players section and see what media others have had success using.
Google is your Friend -
I am using Memorex DVD+Rs. The thing other Memorex DVR+Rs worked great, but certain movies I burned with CSS (in which I had to run ANY DVD in the background) are working horribly.
When I hacked the DVD player and changed it to any region, the DVD player was able to load up the discs that didn't work the other day, but had a hard time getting to the menu and playing the movie (meaning the picture and sound kept skipping).
Any suggestions? Its a good DVD player, and these other DVD+Rs worked in my 3 year old JVC DVD player perfectly. -
Stick with dvd-r will give less issue's and burn at half the maximum rating of the media ... slower is always better for fixation of file's to media ... and keep below 4.3gig .
Take anydvd , and throw it to hell ... fast ... it has issue's .
Go here http://forum.digital-digest.com/showthread.php?t=58318 , download this pgcedit package , as it will also install the psl2 plugins required to rip new dvd title's .
You add the last dvddecrypter , dvdshrink , and imgburn (it come's with fixvts included already) .
From there , just keep up to date with the going's on with pgcedit . -
Just spoke to Samsung and they recomended I use a DVD-R. I am going to copy the movie to a DVD-R and see what happens.
Originally Posted by Bjs
Samsung HT-C450/XEU & Samsung BD-C5300 hacks/codes needed
By raindancerob in forum DVD & Blu-ray PlayersReplies: 8Last Post: 5th Mar 2011, 11:45 -
Samsung VR350. Can't play DVD anywhereelse but in Samsung VR350
By gux70 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 21st Aug 2010, 10:34 -
Samsung BD-P1590 VS Samsung BD-P1500?
By Darkerknight123 in forum DVD & Blu-ray PlayersReplies: 14Last Post: 3rd Jan 2010, 17:51 -
Samsung HT-Z210, Samsung HT-X250
By emmy207 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th Mar 2009, 23:06 -
Stand Alone Samsung HD Tuner vs. Samsung DVD Burner/Tuner
By MacPCConsultants in forum DVB / IPTVReplies: 0Last Post: 7th Jun 2008, 02:42
