After updating firmwares, changing regions, checking ASPI, enabling DMA for both DVD reader and writer, I'm not able to back-up a DVD.
I'm using SlySoft's AnyDVD to decrypt and in the info window for AnyDVD, everything looks alright in the decrypting area.
I've tried three programs with which to burn; Nero's "Copy DVD," SlySoft's CloneDVD, and DVDXCopy Platinum (in both "Simple" and "Advanced" modes).
So here's the problem...
With all of these programs it seems as though they all copy the DVD properly to the TEMP folder, but after copying to the HDD and it's time to transfer to a DVD, I get an error message (different with each program) and am forced to shut the program down, usually resulting in a wasted DVD+R or, even worse, DVD+R DL.
I've had the most success, although not 100%, with CloneDVD where the above happened, but when Windows' Error Reporting window came up, I chose neither to report the problem nor to not send so that CloneDVD would not be forced to shut down as my DVD+/-RW DL drive was still spinning as though copying data. After going to work for several hours (10 to be exact; Plenty for the DVD to finish), I ejected the disc, which was still spinning, and there was data written to it, but only about half of a disc's worth, as you can tell just by looking at the bottom of the disc.
This happens with both DVD+R and DVD+R DL discs and is becoming very annoying. Any suggestions or solutions will be welcomed and are greatly appreciated.
Thanks!
Hardware:
1gb RAM
2.8ghz Intel P4
some SOYO "Dragon" motherboard
Maxtor 6Y120P0 120gb HDD
LG DVD-ROM GDR8162B
Samsung DVD+/-RW DL Lightscribe SH-S183L
You may want to try the combination of Ripit4me and DVDFab Decrypter.
CheersThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety. (Benjamin Franklin). -
Why a combination of the two? I can't just use one or the other?
Sorry, it's the combination of Ripit4me and FixVTS, or DVDFab Decrypter itself.
All freeware, by the way.They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety. (Benjamin Franklin). -
Oh, OK. Thanks. Then which program do you suggest for burning the output files?
DVDFab HD Decrypter : Is DVD to HDD and Blu-ray to HDD decryption FREE?
By Bonie81 in forum DVD RippingReplies: 2Last Post: 8th Jun 2011, 15:28 -
Copying from standalone hdd recorder's hdd to pc hdd
By flez in forum ComputerReplies: 7Last Post: 6th Dec 2010, 07:17 -
What format for VHS to HDD to TV? Playing off a HDD instead of DVD?
By Rudyard in forum Video ConversionReplies: 10Last Post: 6th Aug 2009, 20:46 -
HDD swap! Faulty 'Funai HDR-B2735' vcr/hdd/dvdr ... use HDD in a JVC ???
By StuR in forum DVD & Blu-ray RecordersReplies: 6Last Post: 9th Oct 2008, 13:38 -
how to make copy of system hdd to another bigger hdd and replace
By deejay.2001 in forum ComputerReplies: 6Last Post: 28th May 2008, 19:29
