in another machine/pc. my ILO dvd DVDR04 is bad!. help me, thanks.
do not load movie in non finalizing DVD+R
thanks in advanced.
Finalizing is an option that is chosen during the burning of the disc. It usually can't be done after a disc is already burned unless you are creating multisession discs. Most standalone players will only read the last segment of a multisession disc if they can read it at all.
Google is your Friend -
Go with ZippyP's recommendation ... but I would try and locate someone with the same machine first .
is a home video recorder, ILO DVDR04. i send a e-mail to ilo, but not answer. may be the ILO machine is dead. but thanks, the topic is current open, for other help!.
when i run the ImgBurm, the program say that the disc are empty. is not problem to finalizin?Originally Posted by ZippyP.
i receiv a e-mail from ILO, and i update the player from the firmware website, but now, all DVD+R is fail to read. even current finalizing from the same machine. -
i have had 4 ilo dvdr04's they all did what yours did the recorder pooped out i think it was because the recorder did not get enough air so it burned up if you have a stand alone dvd recorder like gos in a computer it has to be a 16 speed drive 20 speed mite work but i have not tried it it can be double layer or not i bought a LG MODEL # GSA-HIOL - IT WORKS PERFECT I CUT A HOLE ON THE TOP OF THE PLAYER TO RUN THE STRAP AND POWER CORD THAT WHENT TO THE RECORDER I TRIDE A LITEON 16 SPEED IT WORKS FINE EXCEPT SOME TIMES WHEN YOU FAST FORWARD IT FREEZES UP BUT ALL YOU HAVE TO DO IS TURN IT OFF AND RESTART IT I HOPE THIS HELPS UALL BUT LIKE I SAID IT HAS TO BE A 16 SPEED ARE IT WILL NOT WORK
DVD Finalizing Time
By RumCay1121 in forum Newbie / General discussionsReplies: 8Last Post: 9th Dec 2010, 00:38 -
Finalizing a DVD
By calili in forum Newbie / General discussionsReplies: 7Last Post: 29th Mar 2010, 16:40 -
Finalizing a DVD
By gmcsew in forum MacReplies: 24Last Post: 18th Jul 2009, 23:07 -
Messed up finalizing a dvd
By spunon in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2009, 15:06 -
DVD finalizing problems
By 1234567 in forum Authoring (DVD)Replies: 3Last Post: 22nd Nov 2008, 23:11
