    Jan 2007
    Poland
    Hello
    I'd like to change the aspect ratio of Menu on 16:9,
    because my authoring software (Ulead DVDWorkShop2) can't do it.
    WorkShop2 always make Menu as 4:3.
    I have changed aspect ratio of Menu use PGCEdit (my first steps).
    I have clicked on "Domain Stream Attributes" and have changed the attributes for the Menu stream (with 4:3 - on 16:9 Automatic letterbox).
    On TV, Menu has looked very well (16:9) but hightlighted (selected) buttons hasn't.
    Every hightlighted areas still look as 4:3.
    What wrong I did?
    Please, Help me.
    Gregory
    Apr 2004
    Miskatonic U
    The subpictures also have to be rendered for 16:9. Basically, you can author a 16:9 video in DVD Workshop 2 with 4:3 menus, and use external apps to alter the flags so the video displays 16:9, but if you want to have 16:9 menus, I suspect you have to author in software that supports them natively.
    Read my blog here.
    Jan 2007
    Poland
    You are right, but:
    - I can't use another software because I have bought it
    Do you know how to change Menu aspect ratio use PGCEdit?
    Apr 2004
    Miskatonic U
    PGCEdit can only change the flags, but it won't (and can't) alter the subpictures. A lot of discs have 4:3 menus and 16:9 video. It works better on 4:3 TVs, and it is easier to author (which is why DVD Workshop only does 4:3).
    You made your choice - you will have to live with it.
    Edit :
    The only other option I can think of would be to author your menus in GUIForDVDAuthor as 16:9, then see if PGCEdit can be used to replace your 4:3 menus with the new ones. Of course, you could also just author in GUIForDVDAuthor instead.
    Read my blog here.
    Jan 2007
    Poland
    My Menu it is only JPG file (stable) and I accept some (litle) distortion.
    I want to change flag in PGCEdit but I dont know how to do it.
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Look up Aspect Ratio in the online documentation and it will walk you through it.
    I suspect that IFOEdit or IFOAR2WS will be much quicker and easier to use.
    The issue you may have is that the sub-pictures won't line up correctly with the menu when you play it back afterwards.
    Try IFOAR2WS first.
    Read my blog here.
