    Jan 2007
    Italy
    Hi everybody,
    I'm trying to convert with ffmpegX (0.0.9x r2) a trasport stream file registered with a Dreambox, but there is no way to do it. I've tried the same file with other presets (iPod mpeg-4 480W and XviD ffmpeg) with success.
    The info on the progress application says:
    Encoding started on Wed Jan 31 20:56:19 CET 2007
    x264 [info]: using SAR=1000/1001
    x264 [info]: using cpu capabilities Altivec
    mp4 [info]: initial delay 0 (scale 25000)
    movtoy4m
    Copyright 2002-2006 Johan Lindström
    All rights reserved..
    ERROR: Could not open movie: /Users/carlo/Desktop/Bean.ts
    Encoding audio..
    x264 [info]: final ratefactor: 47.25
    usage: movtoway -o output.wav movie.mov
    I have no idea what I'm doing wrong, someone have an idea.
    Jan 2007
    Italy
    Update:
    I've found out that this is happening when I use the x264 codec, with ffmpeg or mencoder everything is fine.
    Any idea why and how to correct it?
    Jan 2007
    Italy
    I still don't get it I've tried different configuration but no way, the progress application starts and in less the a second it says "finished". The error is always the same:
    ERROR: Could not open movie: /Users/carlo/Movies/Bean2.ts
    Why? The movie is there!!!
  4. This process is using Quicktime to read the input file, so if your Quicktime Player cannot open the TS file the same will happen to ffmpegX. I suggest to use MPEG Streamclip to extract the TS file as MPG. You will still need the Apple mpeg-2 player component to read mpeg-2.
    Jan 2007
    Italy
    Thanks major, infact the TS file cannot be opened by quicktime, I've converted it with MPEG Streamclip to MPEG, then I've tried again but there was a problem with the audio part, here is the log file:
    Encoding started on Sat Feb 3 19:50:28 CET 2007
    movtoy4m
    x264 [info]: slice I:556 Avg QP:18.65 size: 19219 PSNR Mean Y:48.22 U:49.84 V:50.82 Avg:48.76 Global:48.12
    x264 [info]: slice P:127563 Avg QP:21.58 size: 3959 PSNR Mean Y:45.41 U:47.57 V:48.77 Avg:46.07 Global:45.34
    x264 [info]: mb I I16..4: 46.3% 0.0% 53.7%
    x264 [info]: mb P I16..4: 4.4% 0.0% 3.5% P16..4: 42.0% 0.0% 0.0% 0.0% 0.0% skip:50.1%
    x264 [info]: final ratefactor: 20.71
    x264 [info]: PSNR Mean Y:45.418 U:47.584 V:48.783 Avg:46.077 Global:45.351 kb/s:805.00
    encoded 128119 frames, 8.38 fps, 805.03 kb/s
    Encoding audio..
    error: could not convert audio track!
    Computing levels...
    normalize: WAV header not found
    normalize: error reading /Users/carlo/Movies/Bean2.mpeg.ff.wav
    FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
    Mac OSX universal build for ffmpegX
    configuration: --enable-mp3lame --enable-gpl --disable-vhook --disable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-pthreads --enable-x264
    libavutil version: 49.0.0
    libavcodec version: 51.9.0
    libavformat version: 50.4.0
    built on Apr 15 2006 08:41:02, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666)
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/carlo/Movies/Bean2.mpeg.ff.video.mp4':
    Duration: 01:25:24.7, start: 0.000000, bitrate: 805 kb/s
    Stream #0.0(und), 25.00 fps(r): Video: h264, yuv420p, 640x352
    /Users/carlo/Movies/Bean2.mpeg.ff.wav: Unknown format
    Apparently ffmpegX does not recognise the audio after converting it with MPEG Streamclip!!! Tried 2 more times but always the same result
    So I've done it again from scrath (from the original TS) only this time using "H264 [MP4] (ffmpeg)" and everything went fine.
    Thanks again
