Turn auto-ripple off when adding the audio and the clips won't move. Auto-ripple is one of these features that is great when you need it, and really annoying when you don't. You get used to turning it on and off as required.
As for frames re-appearing - drag the clip by grabbing the clip itself, not the end-point. Remember that Vegas editing in non-destructive. If you trim a clip on the timeline (by splitting, for example), then drag the end of the clip out, you get everything back.
For DVDA, look at the properties for your title, and set the end action to return to the menu.
Results 31 to 32 of 32
Read my blog here.
Wow, the auto ripple thing again. Guess I'll be dealing with that one more often than I thought.
DVDA setting did the trick. Thanks again. You're Da Man...
Grainy video footage
By ccorwin in forum Newbie / General discussionsReplies: 2Last Post: 11th Feb 2011, 02:24 -
movie filter for vegas 9
By mol3000 in forum DVD RippingReplies: 5Last Post: 6th Feb 2010, 01:45 -
Video quality is grainy
By Mysterio in forum Newbie / General discussionsReplies: 14Last Post: 5th Mar 2009, 13:03 -
Filter Rendering Workflow in Vegas Pro 8
By SCDVD in forum EditingReplies: 3Last Post: 31st Dec 2008, 21:37 -
Help With Grainy Looking Video
By MAXIMUS01CAN in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 30th Jan 2008, 17:00
