  1. hey yall...looking for some help or advice...
    just recently acquired a dvcpro cam and deck...
    wanted to know if there was a capture card i could install into my pc that would accept the video input...i know of a capture card for the deck itself is available...but it cost a grand...is there anything i could do to get around that...like a card that has a bnc connector on it?
    or maybe you know where i can get a cheaper version of a capture card for a dvcpro deck...
    thanks...
    breaking news is my life...
  2. Member Dr_Layne's Avatar
    Nov 2002
    Does the deck and camera have a firewire port? If so that's all you need.
    Steve
  3. the deck nor the camera have firewire ports on it...that's why i'm asking for help...thanks for the quick reponse though...
  4. Banned
    Dec 2005
    Canada
    check your documentation (or get it online) I think you have missed something
  5. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    List the model numbers. Pro cams usually use uncompressed SMPTE 259M workflow.
    http://en.wikipedia.org/wiki/Serial_Digital_Interface
    But most decks (if not camcorders) have an IEEE-1394 DV port for computer interface. You have several ways to work.
    1. All DV format as done at the consumer and prosumer level.
    2. All SDI. For this you will need to pimp your computer to full workstation level with RAID to handle 270Mb/s uncompressed serial data flows. Realtime compositing is the next step up from there requiring 3-4 synchronized streams. Look to SDI cards from AJA or Blackmagic as a start.
    3. Use a SDI to DV converter like the Datavideo DAC-5 or the Canopus ADVC-1000. See
    http://www.videoguys.com/dac.html
    http://www.canopus.com/products/ADVC1000/index.php
    Others:
    http://www.zotzdigital.com/item.php?pid=211&cid=249
    http://www.miranda.com/product.php?i=47&l=1
    http://www.spcomms.com/daportal/
    Hopefully your deck has an IEEE-1394 port or has one as an option.
  6. wow!...thank you all for the quick responses...it helps alot...although i'm not in tune with all the jargon...so i'll show what the deck looks like from the back...
