Hi all
I have got a "thaipod" that is causing me a few issues.
Essentially it plays AVI files, providing they are 25fps mpeg4 encoded with mp3 audio (as far as I can tell). The machine is superb in all aspects other than this, and I can't afford to replace it at the moment.
I have a file that gspot tells me is 23fps, encoded using xvid 1.1.0 beta 1 and using mpeg-1 layer3. It doesn't matter what I use to re-encode it, the audio goes out of sync.
I am pretty technical, but have had no cause to do much more than 1 click conversion solutions up until now, so any help people could give would be appreciated.
I am running the latest FFDShow codecs on the PC as they are the only ones I have found that will play whatever I through at it without issue.
Thanks in advance
Dave
Update: It plays video that gspot reported as DivX 4 (OpenDivX)
This is converted using Blaze Video Magic, but Blaze only uses 0x0050 MPEG-1 Layer 2 so I get no audio
Blaze is really quick, so it is a shame it won't use layer 3, or is it quicker to extract and convert the audio somehow? Sorry for all the questions, but if someone knows of a 1 click solution it would be superb -
Figured it out.
TMPGEnc 3.0 XPress and the DivX 6.5 codec sorted it for me.
Although if anyone could suggest a better codec that GSpot would report as MP4 I would be greatful, as the file size is around 50% bigger than I hoped
Thanks all
Dual or Multi Audio AVI with subtitles (MPEG4 XviD DivX)
By DereX888 in forum User guidesReplies: 16Last Post: 20th Dec 2012, 16:24 -
AutoGK: stopped converting/a MP2 audio to MP3 [TV cap--> xvid/avi encodes]
By bruckwine in forum Video ConversionReplies: 7Last Post: 18th Jun 2010, 01:46 -
Gordian Knot AUDIO PROBLEM: DTS to VBR MP3? (HD 720p.mkv to SD XviD.avi)
By Randm in forum Video ConversionReplies: 2Last Post: 31st Jul 2009, 02:49 -
Passthrough mpeg4 video but re-encode mp3 audio to AAC?
By live4ever in forum ffmpegX general discussionReplies: 5Last Post: 8th Sep 2007, 11:56
