    Apr 2006
    Well I understand that when you set it to the "Highest", it will generate better quality....but then if we set it to the "Fast" or "Standard", would the quality be really bad or would it be just about the same?
    Amd can someone explain to me the difference among the options "Fast", "Standard", "Highest"? What does each option do?
  2. Going Mad TheFamilyMan's Avatar
    Jan 2004
    south SF bay area, CA USA
    Usually long gone and forgotten
  3. Member ntscuser's Avatar
    Mar 2003
    There is a definite improvement from using the highest setting.
    And can someone explain to me the difference among the options "Fast", "Standard", "Highest"? What does each option do?
    Fast = lowest quality, quickest encoding
    Highest = highest quality, slowest encoding
    Standard = somewhere between the other two
