We have recently purchased a Toshiba HDD & DVD Video Recorder (RD-XS52) and use it to record digital video from an underwater camera. During a project we usually collect numerous hours of footage and I need to edit the footage down before burning to DVD.
In the past, using a digtal camera (miniDV), we transfer the video via firewire to Pinnacle Studio V9, make edits, add text/titles than author DVD for distribution. I would like to do the same with the video on the Toshiba HDD.
In case you are not familar with this Toshiba Recorder, there is an option for DV in, but no option for DV out.
Is this possible? Any help would be appreciated, I have already spend hours making no progress.
Thanks,
You would probably have to remove the hdd from the dvd recorder to be able to connect it directly to the pc.
You can also output to dvdrs and reedit them on your computer.
toshiba dvd video recorder dr430ku
By tim37 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 13th Apr 2010, 21:12 -
Toshiba HDD dvd Recorder RD-XS35SU 160GB HD
By sonny crocket in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2009, 13:55 -
Replacing HDD on Toshiba RD-XS52 DVD Recorder?
By DVWannaB in forum DVD & Blu-ray RecordersReplies: 17Last Post: 9th Feb 2009, 15:59 -
Disk burning issues with Toshiba HDD Recorder
By leafslover in forum DVD & Blu-ray RecordersReplies: 1Last Post: 18th Sep 2007, 00:39 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 22:19
