Hey all!
I have a basic portable DVD player and an awesome new LCD monitor - i got a new computer 'package'. Is there any way to connect just the monitor to the DVD player? I would love to have that in my room instead of a huge tv...
thanks!
If your DVD player has VGA or DVI outputs and if the monitor has a corresponding VGA or DVI input AND accepts the resolution/refresh rate the player outputs, then it should work fine. The only way to know for sure would be to try it and see.
Google is your Friend -
ID the model numbers.
Usually a computer LCD monitor needs a display card to do the various format conversions. That is why they are cheap.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
kworld offers a LCD to TV box. You can find the specs here -
http://www.kworld.com.tw/en/index_analog.htm
This has quite a few inputs to choose from.
Can I use a headrest monitor as my server monitor when traveling
By regtcnlgy in forum ComputerReplies: 4Last Post: 17th Aug 2009, 08:43 -
DVD player for use with LCD Monitor
By siluet in forum DVD & Blu-ray PlayersReplies: 4Last Post: 15th Aug 2007, 13:53 -
Hooking up my DVD player to pc monitor
By pobasted in forum DVD & Blu-ray PlayersReplies: 3Last Post: 1st Aug 2007, 05:32 -
connect dvd player to pc monitor
By kiet950 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 19th Jun 2007, 12:26 -
Using LCD Monitor with DVD Upconverter
By e39mofo in forum DVB / IPTVReplies: 1Last Post: 18th Jun 2007, 14:37
