I recently re-authored an episodic DVD, and after removing the bits and pieces I didn't want I created a new menu command structure with PGCEdit. I tried to check the functionality of the DVD by using the "trace"-function in PGCEdit, and it seemed to work the way it should. I burned a copy and tried it in my stand-alone player, and now it behaved differently - after playing episode 8 it was supposed to jump to menu 3 but it went to menu 2 instead. I put the same disc back in the computer and tried it with PowerDVD and it worked the way I intended it to again.
I grew frustrated enough to author the complete DVD from scratch and it works fine now, that's not the problem, but what I want to know is: is this normal? Are PowerDVD and PGCEdit too forgiving, or is my stand-alone behaving strange?
Is there any way to find out if the DVDs I have made are completely DVD-compliant, meaning playing the way I want them to on all stand-alones? It would be frustrating to have to re-author my home-made films if I was to buy another DVD-player...
Results 1 to 1 of 1
In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move.
DVD plays differently on VLC vs other software/hardware?
By PartyRambo in forum Authoring (DVD)Replies: 5Last Post: 31st Oct 2011, 04:29 -
Why does this movie playing software not work? (Bluray software)
By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 04:18 -
Just doesn't work, jumps to finished
By leavemealone347 in forum ffmpegX general discussionReplies: 55Last Post: 23rd Sep 2008, 20:25 -
windows media player jumps
By jyeh74 in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2007, 04:43 -
DVD Creator Software won't work on our DVD player
By jay-jay in forum Newbie / General discussionsReplies: 7Last Post: 25th Jul 2007, 22:04
