And obvious too...
(My fav. is No.3)
AMAZINGLY SIMPLE HOME REMEDIES
1. If you are choking on an ice cube, don't panic. Simply pour a cup of boiling water down your throat and presto. The blockage will be almost instantly removed.
2. Clumsy? Avoid cutting yourself while slicing vegetables by getting someone else to hold them while you chop away.
3. Avoid arguments with the little woman about lifting the toilet seat by simply using the sink.
4. For high blood pressure sufferers: simply cut yourself and bleed for a few minutes, thus reducing the pressure in your veins. Remember to use a timer.
5. A mouse trap, placed on top of your alarm clock, will prevent you from rolling over and going back to sleep after you hit the snooze button.
6. If you have a bad cough, take a large dose of laxatives, then you will be afraid to cough.
7. Have a bad toothache? Smash your thumb with a hammer and you will forget about the toothache.
Results 1 to 1 of 1
Import home-burned DVDs to PC for simple editing?
By cookieJones in forum Capturing and VCRReplies: 16Last Post: 22nd Oct 2011, 21:46 -
Simple task, not so simple (rip/quicksync)
By Trife in forum Newbie / General discussionsReplies: 10Last Post: 12th Aug 2011, 19:57 -
sony carl zeiss vario-tessar 120x FIREWIRE PORT IS FRIED - Any remedies ?
By Geoff J in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 25th Feb 2010, 06:45 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 22:38 -
Looking for a simple program to redo dvd menus for my home movies
By brycej817 in forum Authoring (DVD)Replies: 2Last Post: 24th Jan 2008, 14:31
