This is the error message from ffmpeggui-
And these are the properties of the avi file from which I am trying to extract audio-
Format : AVI
Info : Audio Video Interleave
Family : RIFF
File size : 1.10 GiB
PlayTime : 1h 57mn
Video #0
Codec : DivX 5
Family : MPEG-4
PlayTime : 1h 57mn
Width : 640
Height : 480
Aspect ratio : 4/3
Frame rate : 23.976 fps
Resolution : 8
Chroma : 4:2:0
Interlacement : Progressive
Writing library : Lavc51.1.0
Audio #0
Codec : MPEG-1/2 L3
Family : MPEG-1
Info : MPEG-1 or 2 layer 3
PlayTime : 16s 837ms
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 44 KHz
Results 1 to 9 of 9
Has nobody encountered this error before or is it just to common for you to bother replying?
Personally never had any problems with ffmpeggui, but then again, I rarely load the AVI directly. I usually either decode the audio to wav in Goldwave, or at least demux it with VirtualDub.
At this point it's hard to tell what's wrong, but it's most likely some anomaly in your source file.
It can be the AVI as such, or the audio stream in the AVI or maybe even the video stream - who knows - but I suggest you at least demux the audio before encoding it with ffmpeggui.
And - Please don't bump your topics - wait at least a day or two.
/Mats -
Look at the playtime of the video, 1 h 57 min. and the playtime of the audio, about 17 seconds. I guess, as mats suggested, there is something wrong with your source avi.
Cheers.They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety. (Benjamin Franklin). -
Originally Posted by Abond
Just try the extract to AC3 again. I get this error from time to time.
Originally Posted by uniks
Give it a new name then click Save.
Good luck.
Extracting audio from flv
By Mike99 in forum AudioReplies: 30Last Post: 22nd Apr 2011, 08:31 -
Extracting Just The Musical Audio
By niteghost in forum Authoring (VCD/SVCD)Replies: 9Last Post: 6th Jan 2011, 05:09 -
Extracting audio from .ts
By leopardx in forum Video ConversionReplies: 2Last Post: 23rd Apr 2009, 16:22 -
Extracting Music from Audio CD
By prayami in forum AudioReplies: 4Last Post: 4th Aug 2008, 17:59 -
extracting audio from submenu
By juetenglord in forum Authoring (DVD)Replies: 3Last Post: 18th Feb 2008, 07:29
