    Aug 2004
    Hungary
    Hi!
    I'm trying to convert my mkv file to avi in order to play it on my standalone player.
    I've read many tutorials, but none of them worked for this file.
    I installed matroska pack.
    I tried demuxing the mkv with Virtualdubmod. I didnt work but no problem the tutorial said it may happen.
    Then I tried mkvextract. But all I got was a 0 kB audio (ac3) file, and an empty chapters.txt.
    Then I tried winavi, alltoavi, river past video cleaner and then super.
    Winavi doesnt do anything, it stays on 0%.
    Alltoavi cannot be used either...
    River past creates a very small avi file that is of course not good.
    Super stops with error, not really specifying what kind of error.
    Can anyone tell me what's going on?
    I show you what mediainfo says about the file:
    General #0
    Complete name        : I:\214.mkv
    Format               : Matroska
    File size            : 1.08 GiB
    PlayTime             : 43mn 14s
    Bit rate             : 3559 Kbps
    Encoded date         : UTC 2007-01-23 05:04:34
    Writing application  : mkvmerge v1.8.1 ('Little By Little') built on Nov 25 2006 16:14:30
    Writing library      : libebml v0.7.7 + libmatroska v0.8.0
    Video #0
    Codec                : MPEG-4 AVC
    Codec/Info           : MPEG4 ISO advanced profile
    PlayTime             : 43mn 12s
    Width                : 1280 pixels
    Height               : 720 pixels
    Aspect ratio         : 16/9
    Frame rate           : 23.976 fps
    Language             : English
    Audio #0
    Codec                : AC3
    Codec/Info           : Dolby AC3
    Channel(s)           : 6 channels
    Sampling rate        : 48 KHz
    Please help!
    Many thanks!
    Dec 2004
    Australia
    If mkvextract can't extract, then I would say that there is something wrong with the file. Anything muxed via mkvmerge should be demuxable via mkvextract.
    Check that you are using at least v1.8.1. Latest is I think v2.0.0.
    Aug 2004
    Hungary
    Damn, I cant believe it thanks...
    I used the latest gui, had the latest mkvtoolnix but not in the same folder. Damn.
    Now it works...
    Thanks again
    Aug 2004
    Hungary
    Right I'm stuck again.
    Now I have a .h264 file. I'd like to convert it to divx.
    Virtualdub(mod) doesnt recognize this ext. Even if i open the file it says cannot detect file type.
    Super cannot convert it... I tried MEncoder, ffmpeg with and without directshow... But it can play it! its only that it cant encode it.
    Winavi doesnt recognize it either.
    I'm starting to think what i want is impossible...
    Pls help a bit more...
    Aug 2005
    Right here
    They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety. (Benjamin Franklin).
    Dec 2004
    Australia
    mencoder and ffmpeg definatly both support raw H.264 streams. Then again they both also support mkv input. With mkv there are no issues with framerate detection either.
