I have loads of music videos on my computer which program is best to put them to dvd?
I have tried dvdlab pro and its asks to transcode the files which program can i use to avoid doing this?
music videos in what format? .mpgs? what video frame size? fps? identify the clips with latest gspot. dvd requires a specific format, www.videohelp.com/dvd#tech
Yes, you must transcode / convert them if you want it as a DVD-Video that works on DVD Players.
You can just burn them as a data dvd but they will only work on divx dvd players....if the avi clips are in divx or xvid then. -
Which are the best program to do it with without dvd menus, so they start 1 after the other?
clarky man, I do this all the time and I have found (although it takes more time) that using sony vegas I encode each video using a variable bit rate 2 pass encode 8max 6avg 192,000min 720x576 (i believe it 720x480 if your ntsc) video only, then I encode the audio as AC3 so I end up with 2 files, the video and the audio (make sure they have the exact same name and just the extention is different i.e. u2 - desire.mpeg and u2 - desire.ac3.
Next you load up sony dvd architect and load the videos into there and it will automatically select the AC3 file as the audio when set to AC3 mode in the preferences. There is no more transcoding here as all the settings were done correct from vegas and you just organise your vids and then burn.
I get around 25 videos per DVD using this method.
Before I encoded them individually I used to use a more basic program called roxio easy dvd creator which would encode them all using constant bit rates giving me about 12 for each disc. This program was easier in that you just plonk your vid in and it is the authoring and encoding program all in one but doesnt have many options in how you can encode your vids.
The first option gives me great results. -
ConvertXtoDvd
All in one, convert's pretty much any file type to dvd, with or without menu, and will even burn to dvd.
I usually use it just for converting then burn the resulting VIDEO_TS folder with ImgBurn.
Any guides on creating continuous bluray menu music?
By aciras in forum Authoring (Blu-ray)Replies: 0Last Post: 12th Oct 2011, 13:36 -
Replace Background Music with New Music without affecting other tracks
By PaulDHolloway in forum AudioReplies: 3Last Post: 10th Apr 2008, 13:56 -
How To Rip and Manage Music DVDs just like Music CDs in JRiver Media Center
By jmone in forum User guidesReplies: 0Last Post: 13th Oct 2007, 19:15 -
Can I burn a music video along with music trax onto the same disc?
By Kalla B in forum Newbie / General discussionsReplies: 0Last Post: 4th Jul 2007, 13:02 -
Creating Music Video DVD for in-car system
By calypso99 in forum Newbie / General discussionsReplies: 1Last Post: 17th May 2007, 11:21
