Hi all,
I wanted to make backups of some dvds I had. I put them on my hard drive using Mactheripper, resulting in the video_ts and audio_ts folder structure. I used the "img" function of ffmpegx to make a .img file, which I burned using Disk Utility. The resulting disk would, as far as I could tell, only play through linearly (ie the menus were lost). I also tried buring with Toast, but the video_ts folder is nearly 7GB, so it will not fit on the DVD-Rs that I have.
Does anyone have any ideas? Thanks!
Burning from VIDEO_TS with Toast 7+ allows you to utilize its Fit-to-DVD video compression, shrinking it to regular DVD-R size.
The presence of menus is just like the ripped output, regardless of imaging or burning app (unless the app has options otherwise). In MTR, only a full disc extraction would preserve menus, if present on the source disc.
FFMpegX Audio problems
By Cowchan in forum Newbie / General discussionsReplies: 0Last Post: 11th Dec 2011, 10:00 -
ffmpegX DVD Burning - Weird Runtime After Conversion??
By tictacjak in forum Authoring (DVD)Replies: 0Last Post: 7th Sep 2011, 11:31 -
Muxing problems with ffmpegx
By Themroc in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2009, 19:49 -
Problems with ffmpegX
By KeepItSimple in forum MacReplies: 2Last Post: 5th Apr 2008, 20:46 -
ffmpegx Problems! Help!
By The Sumerian in forum ffmpegX general discussionReplies: 4Last Post: 10th May 2007, 00:36
